Re: Cowl Hood
[Re: John Burdine]
#1565823
01/21/14 09:04 PM
01/21/14 09:04 PM
Posts: 2,601 ky
headhunter
ky
Glasstek 6"
that's a good looking demon
Re: Cowl Hood
[Re: fishy340]
#1565824
01/21/14 09:10 PM
01/21/14 09:10 PM
Posts: 2,601 ky
headhunter
ky
what about both
Now that this car is a streeter,want to sell the hood or trade lmk.
Thats the set up i want
I don't know ive thought about getting another hood but it kinda grows on you lol
Re: Cowl Hood
[Re: headhunter]
#1565826
01/21/14 10:43 PM
01/21/14 10:43 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
So does the paint job
Re: Cowl Hood
[Re: headhunter]
#1565827
01/22/14 10:07 AM
01/22/14 10:07 AM
Posts: 13,543 Marion, South Carolina [><]
an8sec70cuda
if im not mistaking the carbs sit to high in the scoop to seal them
Using drop bases on the carbs will fix that. Seen it done many times. If it was worth any power on those cars, I'm sure they would be doing it.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
Re: Cowl Hood
[Re: Thumperdart]
#1565829
01/22/14 03:33 PM
01/22/14 03:33 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
If you`re talking about the Hemi guys, I read somewhere that they can`t use air pans.................
Sure they can, problem is they don't help. The scoop has to be kept within factory dimensions and as discussed in other threads is not high enough to do any good. Sealing the scoop would probably cost it air vs letting it get some underhood air unsealed.
Monte
Re: Cowl Hood
[Re: Monte_Smith]
#1565830
01/25/14 01:39 PM
01/25/14 01:39 PM
Posts: 232 NYC
Dartari
NYC
Monte
Hi Monte in your opinion is there an advantage in the glasstek 5" six pack scoop over the glasstek 6" cowl hood thanks for any insight you may have
Re: Cowl Hood
[Re: Monte_Smith]
#1565831
01/25/14 02:47 PM
01/25/14 02:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Monte
... they just arent tall enough to get up into the real air flow... they MAY be getting a good percentage of their air flow from inside the hood area.. I picked up ET and 3 MPH on my scoop when I sealed it
Re: Cowl Hood
[Re: headhunter]
#1565837
01/26/14 02:25 PM
01/26/14 02:25 PM
Monte_Smith
North Alabama
is my carb up in the scoop high enough to be any good?
I would venture a guess that this car will run the SAME, with or without a plug in the scoop
Monte
