Page 3 of 5 1 2 3 4 5
Re: Just another '74 Callenger [Re: Scott Carl] #156441
04/21/10 11:57 AM
04/21/10 11:57 AM
Omaha, Nebraska
Scott Carl Offline OP
Omaha, Nebraska
The foam isn't too bad but needs some patching where it was exposed when the covers failed. However, all of the foam under the "tuck 'n' rolled" panels will be replaced as I have to sew through it and the vinyl to form the pseudo T'n'R Here's the front bucket cover:
Re: Just another '74 Callenger [Re: Scott Carl] #156442
04/21/10 12:04 PM
04/21/10 12:04 PM
Omaha, Nebraska
Omaha, Nebraska
One more:
Re: Just another '74 Callenger [Re: Scott Carl] #156443
05/19/10 10:56 PM
05/19/10 10:56 PM
Omaha, Nebraska
Omaha, Nebraska
One of these days I'll start showing some progress LOL. In the mean time, yesterday I pull the pan off the 904 to see why it won't shift into drive and found fluid that looks like strawberry milkshake. I've been told its due to the submersion issue. (see OP)The transmission is basically toast. The amazing thing is that it has any go-power at all (got 1st and 2nd) but I guess I will be spending the cash I had rat-holed for engine work on a tranny kit first
While I had the front of the car at eye level, I took the grill and front valance off and took the cop bumpers off. IMHO, even without the grill and valance it looks better already without those @#$%& shin busters.
Onward and forward
Re: Just another '74 Callenger [Re: Scott Carl] #156444
05/20/10 09:35 AM
05/20/10 09:35 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Scott, while you are there, why don't you drill a couple holes in the bumper brackets and move the bumper in. That way you can do away with the rubber bumper fillers. There are a couple square holes in the brackets that you can drill out to 5/8". That will allow you to move everything back to where the 70-72's were. I'm afraid that the bumper will look too far forward if you don't.
Re: Just another '74 Callenger [Re: burdar] #156445
05/20/10 02:13 PM
05/20/10 02:13 PM
Omaha, Nebraska
Omaha, Nebraska
Thanks Darren. That's basically my plan. Do you mean the bracket to bumper or bumper to frame holes?. I was studying the brackets; even had the bracket to frame bolts out 'cept the rear ones so the bumper could hang down. Not sure how the brackets can slide back without hitting the radiator support where that split without some modification. Do you have any pictures?? Otherwise I was going to do just that; cut and refab the brackets. I can see that without the filler strips, the bumper will draw into the space nicely Couldn't get the screws out to take the strips off though. Heads rusted out and I dind't feel like breaking out the cut-off tool just then.
Also, I may even weld and smooth over the bolts to the bumper so no heads are visible but still debating if I want painted or re-chromed bumpers. I've seen both and like both. Decisions, decisions
Re: Just another '74 Callenger [Re: Scott Carl] #156446
05/20/10 02:41 PM
05/20/10 02:41 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I havn't done it personally but have read that it can be done. The brackets that mount to the frame rails have a few square holes in them just forward of the round holes. You are supposed to be able to move the whole assembly back. Here is the link. Look at ResQ911's post.
https://board.moparts.org/ubbthreads/favl...amp;postmarker=
Re: Just another '74 Callenger [Re: burdar] #156447
05/20/10 11:51 PM
05/20/10 11:51 PM
Omaha, Nebraska
Omaha, Nebraska
Thanks again Darren.
I've been trying to get all my "Before" pictures out of the way and realized I haven't show the engine bay yet. Purdy ain't she?. Plain ol 318 in need of some TLC. Nothing special...unless you count the Sears aftermarket A/C compressor. And if you look real close, you can see I'm totally rockin' the sword handle transmission dip stick
Re: Just another '74 Callenger [Re: Scott Carl] #156448
03/31/12 03:44 AM
03/31/12 03:44 AM
Omaha, Nebraska
Omaha, Nebraska
Sheese! Has it really been nearly 2 years since I last posted? Well, in my defense, last summer, I spent a good part reorganizing my garage to better accommodate my hobbies. No I can't pull in and work in the garage. I haven't been able to do that for 15 years due to my other hobby, artistic blacksmithing and fabrication. However, I do have all (or most) of mine and Dad's tools under one roof now and have all of them accessible as well as my fab machines, i.e. welders, drill press, lathe and such, where before, the garage was a mess to work in; everything buried by the honey-do stuff that gets tossed out there "until I get time". But I digress...
Last fall I swore over a mug of my favorite brew that the engine and trans were going to get done this spring and to commit myself, I pulled them out and tore down the engine and wrapped the 904 up with a tarp and stored it for the winter. Monday morning, I took the block to my engine guy for boiling, decking and boring. Not sure how for out the holes were (not much by the fingernail over the ridge measurement), but we should be good at .030 over. I did some quick number crunching, and then googled a cid calculator, and found that at .030 over, it makes a 318 a 322. No real reason to report that except I’m glad I don’t have to go .060 over because that would yield about 327 cubic inches and I ain’t having no 327 in my Mopar!! Just sayin!
The crank mic'd out to near factory specs and so far, the valves are looking pretty good but I'm at the very least, looking at exhaust guides and of course, grinding. Once I get the heads apart and off the engine guy I will clean house and bring the trans in and get started on that. I bought a complete rebuild kit and shift reprogram kit; all new clutches, steels, bushings bands etc.
Well, that’s all to report for now. Next post, I hope to have something picture worthy to include.
Scott
Re: Just another '74 Callenger [Re: Scott Carl] #156449
09/01/12 09:11 AM
09/01/12 09:11 AM
Omaha, Nebraska
Omaha, Nebraska
Well its been a long hot summer but we're making some progress. I had a set back on the block; the original block turned out to be bad. After decking it my machinist discovered a hole in the wall of #5 cylinder. Probably a result of sitting for so long after the flood. (see OP) After finding a donor block, there was another delay as it had a small chip at the top of one of the holes that machinist wasn't sure would come out after it was decked. Fortunately the guy I got it from was willing to trade for another and we moved on. Acid dipped, decked, bored .030" new bearings pistons and rings.
Re: Just another '74 Callenger [Re: Scott Carl] #156450
09/01/12 09:19 AM
09/01/12 09:19 AM
Omaha, Nebraska
Omaha, Nebraska
I couldn't find a degree wheel in town to save me so I did some research and found someone had drawn one up on CAD and posted it on another car forum. I printed it out as large as I could on printer paper and glued it to a piece of sheet metal with 3M spray adhesive and then drilled (hole-sawed) a hole in the center.
Re: Just another '74 Callenger [Re: Scott Carl] #156451
09/01/12 09:24 AM
09/01/12 09:24 AM
Omaha, Nebraska
Omaha, Nebraska
Couldn't do anything until I made a pointer...
I'm using Comp's High Energy cam kit XE256H-10 with a .447/.455 lift and 256/268 duration and I got the cam withing 1 degree of the 106 degree spec using -4 notch on the crank gear.
Re: Just another '74 Callenger [Re: Scott Carl] #156452
09/01/12 01:53 PM
09/01/12 01:53 PM
Omaha, Nebraska
Omaha, Nebraska
Just about done! Ready for paint tomorrow?? (No, it's not gonna be Red )
Re: Just another '74 Callenger [Re: Scott Carl] #156453
09/01/12 01:56 PM
09/01/12 01:56 PM
Omaha, Nebraska
Omaha, Nebraska
Had to make a heat shield for the intake...
Re: Just another '74 Callenger [Re: Scott Carl] #156454
09/01/12 01:59 PM
09/01/12 01:59 PM
Omaha, Nebraska
Omaha, Nebraska
Before I drilled it for the rivets:
Re: Just another '74 Callenger [Re: Scott Carl] #156455
12/10/12 01:19 PM
12/10/12 01:19 PM
Omaha, Nebraska
Omaha, Nebraska
Ready to install:
Re: Just another '74 Callenger [Re: Scott Carl] #156456
12/10/12 01:25 PM
12/10/12 01:25 PM
Omaha, Nebraska
Omaha, Nebraska
Finally got it back in the car:
Re: Just another '74 Callenger [Re: burdar] #156457
12/22/12 05:20 PM
12/22/12 05:20 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I did it, Piece of cake. I also installed a 70 grille that was a little harder. the bumper stuff is self explanatory when you get them off.
Very impressive doing your own seats. it's nice to see someone tackle this project on a low budget using ingenuity instead of cash.
Doug
Re: Just another '74 Callenger [Re: dvw] #156458
12/26/12 02:16 AM
12/26/12 02:16 AM
Omaha, Nebraska
Omaha, Nebraska
Thanks, Doug. Are those your stock bumpers?
Re: Just another '74 Callenger [Re: Scott Carl] #156459
12/26/12 11:53 PM
12/26/12 11:53 PM
new jersey
Black 69 Beeper Offline
new jersey
mine is just another 74 challenger too! 26 years and counting.
Re: Just another '74 Callenger [Re: Black 69 Beeper] #156460
01/01/13 12:09 PM
01/01/13 12:09 PM
Omaha, Nebraska
Omaha, Nebraska
Nice!
