Help me choose a cam for this "stockish" 440 6 pack
#1564248
01/16/14 10:37 PM
01/16/14 10:37 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Hi! I have a 440.6 engine on my 71 cuda. Its been nicely rebuilt. Forged pistons, 9,4:1 compression ratio (to run on pump gas) punched 55 over it displaces 451 CID Bowl ported and port matched 452 cast iron heads with a nice competition valvejob 2.14 intake valves 1.88 exhaust valves stock exh manifolds full exhaust stock 6 pack carbs Car is a 4 speed. 3.54 Dana 60 This is the cam I have installed in it (attached pic). Do you guys think there would be any gains in going to a different Hydraulic grind (I wish to stay with a hydraulic flat tappet). I feel the engine is torquey and really moves at lower rpms but it peaks out and then hits a plateau and stays "flat", i dont feel like it keeps pulling at higher RPMs, specially when Ive taken it to the drag strip.
Re: Help me choose a cam for this "stockish" 440 6 pack
[Re: domingo]
#1564253
01/17/14 02:35 AM
01/17/14 02:35 AM
Posts: 903 Saskatchewan, Canada
cudabin
Factory manifolds and lower compression like yours would work great with a Mr Six pack Cam.
I just finished a similar build and made 450hp...
114 - 115 LSA will help with manifolds.
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: cudabin]
#1564256
01/17/14 09:20 AM
01/17/14 09:20 AM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
Cheers,
Arnie
Did you have a chance to get it to the track last year? Really looking forward to those results.
[Re: domingo]
#1564260
01/17/14 10:01 PM
01/17/14 10:01 PM
Posts: 596 Nashville, Tennessee
Tempest
Yes, it ran a best of 14.2ish on street tires (255 BF Goodrich radial TAs).
What was the MPH?
[Re: Tempest]
#1564261
01/17/14 10:29 PM
01/17/14 10:29 PM
domingo
EL Master
EL Master
Lima, Peru
What was the MPH?
we dont get that at our [Edited by Moparts - Family Friendly Site - Keep it clean] 3rd world track! Just RT ET TT and 60 ft
We race pro tree
I have a slip here of one of the passes:
Reaction: 0.5 60 : 2.51 ET: 14,49 TT: 14,99
[Re: WO23Coronet]
#1564264
01/18/14 05:49 AM
01/18/14 05:49 AM
domingo
EL Master
EL Master
Lima, Peru
You may have other issues if it gases out and you can't get out of 3rd gear in the 1/4, you should be well on your way into 4th by then with 3.54 gears
You are right....
I had to shift into 4th on a few passes---I was crossing just when it begged for 4th-
when I shifted into 4th I crossed the traps right after shifting....
On some passes I shifted on some I didnt!
[Re: domingo]
#1564265
01/18/14 01:11 PM
01/18/14 01:11 PM
Posts: 9,893 Weddington, N.C.
Streetwize
Weddington, N.C.
Comp 270 (what you have) is a decent 440 stock replacement cam but not big enough to wind the motor up.
A couple great Cams were the old Crower 226/236 @.050 and the 231/240 @.050 Hydraulics but 240 on the exhaust is close to the edge of where I like to go with Exhaust manifolds unless you spread the centers out and put the cam in a bit later (both of which is better for higher RPM's on a smallish port 440). The smaller Crower I mentioned went 12.30's @ 111 all day long in my old stock six pack bottom end 440 in a 3710 pound curb weight Charger 4 speed in the heat of the summer, but it had the little Pea shooter hedman headers and a performer RPM with a tweaked 830 on it. and that was 20 years ago with bowl ported stock heads.
About a year ago I sent a customer a custom Ground Bullet Cam single pattern for a 416" small block in his E body automatic with 3.91's and a GV O/D, very broad powerband and still great cruising in OD with 3 friends in the car. So something similar in size should work very well as well for your six pack. With a 4 speed low end torque is not an issue, you almost want to take a little off the bottom and move it up top.
The key is getting the @.050 and @.200 numbers right for the combo so you don't kill torque and have plenty of air/fuel up top. With manifolds your "5th cycle" overlap scavenging assisting the intake charge achieve >100% VE, is fairly narrow and easy to either overshoot or undershoot, the key is to make the most of it because as most of us know 440's, (like Buicks and many fords) really ET on TORQUE, not so much peak HP.
That's why publishing dyno numbers without the corresponding horsepower and torque band charts are about useless to me.
Pretty sure Bob K (Mr six pack) has that figured out pretty well, I never had one but I'm temped to try one next time out, I think he's got that 5th cycle pretty much optimized for the six packs flow characteristics, I think his "cheater" is NHRA stock legal lift (like .465?), don't know if he has a higher lift version. I know Dan Dvorak used to have a stock lift port job that flowed gangbusters up to about .480 lift but then went turbulent, definitely an application specific type port job but I suspect it would work awesomely with the Mr6pack cam.
[Re: Streetwize]
#1564266
01/18/14 02:31 PM
01/18/14 02:31 PM
domingo
EL Master
EL Master
Lima, Peru
Thats waaay beyond my comprehension....LOL
I called BOB K and he said he is having a hard time getting cams ground so he is not doing it at the present moment!!!
I think I will call him again to see if he is having them ground again....or maybe call Scott Brown? Hughes??? Or what about you Wize??? Might want to give it a shot?????
[Re: domingo]
#1564267
01/18/14 03:27 PM
01/18/14 03:27 PM
Streetwize
Weddington, N.C.
I do have an account with Bullet, they've been grinding custom grinds for myself and customers for years.....but I remember Dwayne (Fast68Plymouth) also liked the 231/240 Crower cam, he's a great source for cam grinding as well. In several 'back to back' blind taste tests He and I usually spec cams that are uncannily close to one-other, (ask 70Blackfish as one example) which to me is an honor because I have tremendous respect for him I usually defer to Dwayne for people to buy cams from, after-all Engines are his bread and butter and career but for me it's much more a side-line ( I work full time as an engineer). Hughes has got some nice grinds too but not aware if they do any custom grinds, I'm pretty sure Bullet does there cams now.
[Re: Streetwize]
#1564268
01/18/14 05:09 PM
01/18/14 05:09 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I have a customer with a 440-6 in a road runner that runs 11.90's using a cam that's 241@ .050 on a 113lca but uses slicks and a 3.91 gear.
manifolds, full exhaust, Stealth heads with minor port work, 10.2:1...he does have some 1.5 rockers but not sure which ones...maybe HS? He drives it everywhere he can!!
Brian Hafliger
[Re: Brian Hafliger]
#1564269
01/18/14 05:36 PM
01/18/14 05:36 PM
Streetwize
Weddington, N.C.
Yeah, Brian I'm with you! The cam I put in that 416 stroker with the manifolds was very similar to that 440, a single pattern ~237 @ .050 on 112 in at 107, It's a torque BEAST that idles sweet and still pulled the heavy car up high. I think something similar would work on domingo's car and still have plenty of idle vacuum and part throttle cruise torque. My gut would be to put a 244/246-ish @ .050 solid in it and be a bit better down low AND up high. Wish my old 440 had a set of ported stealth heads and slicks, trying to launch a B/E body on street tires (not even drag radials) was about like launching on ICE. My buddy's Chrger has a 440-6 with a 251/257 @.050 Comp cam and runs high 11's with only 3.23 gears. He's running 2" headers, close to 11:1 and a good 9" converter though, which helps him launch. He drives it everywhere as well. Wouldn't run that cam with manifolds though But he doesn't even run drag radials, he runs that 4 shock (2 mounted horizonally about the rear leaf segment) traction system and it obviously works good. You can still build some awesome 440 combos that are still impressive these days!
[Re: gch]
#1564271
01/18/14 11:24 PM
01/18/14 11:24 PM
domingo
EL Master
EL Master
Lima, Peru
First thing you need is a tach.PERIOD.Past that I would check fuel pressure to make sure you aren't running out of fuel on the top end(especially if using a mechanical fuel pump).
^ Those guys have you covered on cam selection.I will say my okd 440 with the comp 280 cam was done making power aroung 5500rpm so I would suspect the 270 to be dome by 5200 or so.
I thought I was having fuel shortage and I installed a Holley Blue pump with a regulator and set it at 7.5 psi if IRC.
It didnt do a thing for the car, it performed just the same at the track....I tried staying on 3rd but it begged for me to shift into 4 it stayed flat on 3rd and didnt rev more....
When I shifted into 4th I just went thru the traps right after I had shifted.....while starting to rev up.
The engine is a NICELY built engine!!!! I think the cam choice just SUCKS!!!!
Needs to be swapped so my 440.6 can perform like it should!!! Still, it SPANKS my buddys 350 camaro everytime we nail it on the hiway while rolling....LOL....but next time I want to really embarass him.....
[Re: Streetwize]
#1564272
01/19/14 06:36 AM
01/19/14 06:36 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
You cant go wrong with using Dwayne Porter. He is real good and I used his cam in my 493. It did just what I wanted and I am 100% happy. Ron
[Re: 383man]
#1564273
01/19/14 11:06 AM
01/19/14 11:06 AM
Posts: 518 ny
greenmcode
ny
There are many cam gurus out there.. I would let Bob k. or Dwayne set you in the right direction.. These two guys know how to make them work with manifolds and street tires..
Good luck..
1969 A12 R.R. 11.61 117.96 F.A.S.T. STOCK STROKE..
