Re: Just another '74 Callenger
[Re: Scott Carl]
#156441
04/21/10 12:57 PM
04/21/10 12:57 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
The foam isn't too bad but needs some patching where it was exposed when the covers failed. However, all of the foam under the "tuck 'n' rolled" panels will be replaced as I have to sew through it and the vinyl to form the pseudo T'n'R Here's the front bucket cover:
[Re: Scott Carl]
#156443
05/19/10 11:56 PM
05/19/10 11:56 PM
Scott Carl
Omaha, Nebraska
One of these days I'll start showing some progress LOL. In the mean time, yesterday I pull the pan off the 904 to see why it won't shift into drive and found fluid that looks like strawberry milkshake. I've been told its due to the submersion issue. (see OP)The transmission is basically toast. The amazing thing is that it has any go-power at all (got 1st and 2nd) but I guess I will be spending the cash I had rat-holed for engine work on a tranny kit first While I had the front of the car at eye level, I took the grill and front valance off and took the cop bumpers off. IMHO, even without the grill and valance it looks better already without those @#$%& shin busters. Onward and forward
[Re: burdar]
#156445
05/20/10 03:13 PM
05/20/10 03:13 PM
Scott Carl
Omaha, Nebraska
Scott, while you are there, why don't you drill a couple holes in the bumper brackets and move the bumper in. That way you can do away with the rubber bumper fillers. There are a couple square holes in the brackets that you can drill out to 5/8". That will allow you to move everything back to where the 70-72's were. I'm afraid that the bumper will look too far forward if you don't.
Thanks Darren. That's basically my plan. Do you mean the bracket to bumper or bumper to frame holes?. I was studying the brackets; even had the bracket to frame bolts out 'cept the rear ones so the bumper could hang down. Not sure how the brackets can slide back without hitting the radiator support where that split without some modification. Do you have any pictures?? Otherwise I was going to do just that; cut and refab the brackets. I can see that without the filler strips, the bumper will draw into the space nicely Couldn't get the screws out to take the strips off though. Heads rusted out and I dind't feel like breaking out the cut-off tool just then. Also, I may even weld and smooth over the bolts to the bumper so no heads are visible but still debating if I want painted or re-chromed bumpers. I've seen both and like both. Decisions, decisions
[Re: Scott Carl]
#156448
03/31/12 04:44 AM
03/31/12 04:44 AM
Scott Carl
Omaha, Nebraska
Sheese! Has it really been nearly 2 years since I last posted? Well, in my defense, last summer, I spent a good part reorganizing my garage to better accommodate my hobbies. No I can't pull in and work in the garage. I haven't been able to do that for 15 years due to my other hobby, artistic blacksmithing and fabrication. However, I do have all (or most) of mine and Dad's tools under one roof now and have all of them accessible as well as my fab machines, i.e. welders, drill press, lathe and such, where before, the garage was a mess to work in; everything buried by the honey-do stuff that gets tossed out there "until I get time". But I digress... Last fall I swore over a mug of my favorite brew that the engine and trans were going to get done this spring and to commit myself, I pulled them out and tore down the engine and wrapped the 904 up with a tarp and stored it for the winter. Monday morning, I took the block to my engine guy for boiling, decking and boring. Not sure how for out the holes were (not much by the fingernail over the ridge measurement), but we should be good at .030 over. I did some quick number crunching, and then googled a cid calculator, and found that at .030 over, it makes a 318 a 322. No real reason to report that except I’m glad I don’t have to go .060 over because that would yield about 327 cubic inches and I ain’t having no 327 in my Mopar!! Just sayin! The crank mic'd out to near factory specs and so far, the valves are looking pretty good but I'm at the very least, looking at exhaust guides and of course, grinding. Once I get the heads apart and off the engine guy I will clean house and bring the trans in and get started on that. I bought a complete rebuild kit and shift reprogram kit; all new clutches, steels, bushings bands etc. Well, that’s all to report for now. Next post, I hope to have something picture worthy to include. Scott
[Re: burdar]
#156457
12/22/12 06:20 PM
12/22/12 06:20 PM
Posts: 9,827 MI, usa
dvw
MI, usa
I havn't done it personally but have read that it can be done. The brackets that mount to the frame rails have a few square holes in them just forward of the round holes. You are supposed to be able to move the whole assembly back. Here is the link. Look at ResQ911's post.
https://board.moparts.org/ubbthreads/favl...amp;postmarker=
I did it, Piece of cake. I also installed a 70 grille that was a little harder. the bumper stuff is self explanatory when you get them off. Very impressive doing your own seats. it's nice to see someone tackle this project on a low budget using ingenuity instead of cash. Doug
