Re: Just another '74 Challenger
[Re: Scott Carl]
#156421
05/07/09 01:10 AM
05/07/09 01:10 AM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
Black/blackish smoke is from overfueling. Blue would be oil, and white, of course, is coolant typical of a head gasket. What you are describing sounds pretty typical for an automatic choke Mopar, especially if it's not right up to tune. No matter...now the fun starts...and the long process of bringing her back to her former glory. Good luck!
2 Demons...no, not my kids!
[Re: 4speeds4me]
#156422
07/06/09 01:05 AM
07/06/09 01:05 AM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
Finally made some more progress. After pulling the rear glass, I started on some body repair around the frame. Need to order clips for the trim, yet. Vinyl I ordered for the seats is here but I'm waiting until I finish work on the top and windshield/rear glass frames b4 doing upholstery; No room to keep anywhere but in the car when done and I don't want them to get wet soooo Got new axle bearings done and installed. Took it for a test drive today. The rear end noise is gone! That takes a lot of the weight off my mind. I really don't want to learn diff repair right now LOL Also, while driving it, there doesn't seem to be as much smoke as when I first got it running. There's the white smoke at first and a puff when ever I get into the gas pedal after slow cruise, so I guessing mostly head gaskets and the carb loading up. Really need to think about a new fuel sending unit soon too. Before I could go anywhere today, I had to go get gas in the gas can. Fuel gauge no worky and of course, tank was MT. It's always something Pictured is the area I'm working on currently. Pretty; huh?
[Re: ridenlow12]
#156427
07/12/09 09:58 PM
07/12/09 09:58 PM
Scott Carl
Omaha, Nebraska
One down, about ten more to go and I can put the glass back in (of course, after I do the finish work )
[Re: 69bronzeT5]
#156432
10/09/09 01:02 AM
10/09/09 01:02 AM
Scott Carl
Omaha, Nebraska
Well, another season is drawing to a close. Don't suppose it will be finished this year either. Guess that's why its a hobby Rust is all patched around rear glass frame but I won't get the glass back in this year. I have a tarp over it now and my nephew is letting me store it in his garage for the winter. Up side is: its bigger than buddies where I kept it last year, so I could actually work on it. Down side: its a lot further away. Got bored and pulled out the rotten carpet and looky what I found!! If it were easy I guess more people would be doing it LOL
[Re: Scott Carl]
#156433
10/09/09 01:34 AM
10/09/09 01:34 AM
Scott Carl
Omaha, Nebraska
The car has the typical oxidation on all the door and rear interior panels. I don't see me replacing with new ones anytime soon (unless they quit picking the wrong lottery numbers But I noticed that if you scrape the oxidation off, it doesn't look too bad underneath. OK it doesn't look as bad. OK its at least black plastic instead of gray powdery crud that sheds off every time you touch it. So, on another bout of boredom I sat with a beer (or two..ok JEEZE!! THREE!!!) and a dull knife and scraped down both door panels. They looked pretty rough when I was done so I wiped the down with some vegetable oil (it was handy and I couldn't find the Armour-All). IMHO, They don't look too bad! Gonna do the same to the rear panels but there is some material missing all together on the portion where they meet the rear window shelf. Like I said, I'm not trying to do a 100 point car; I may get new panels someday, but for now I'll live with them and maybe see if I can do something with the leftover seat vinyl in the way of a "cover-up"
Re: 1965 cuda project
[Re: Scott Carl]
#156434
10/09/09 07:29 PM
10/09/09 07:29 PM
Posts: 20 Wise, VA 24293
MECCprofessor
Wise, VA 24293
Here is a project car I found sitting in the woods since 1972 on my friends property. The car has a 273 commando engine that is seized. Currently I ran out of money for the project and itis sitting until spring (because I am working on my sons 68 cougar xr7). I have a set of front disc brakes from a 66 valiant, replacement gastank, and new fuel lines ready to go in. Anybody know where I can get the brake booster re-built. The hood is sitting in the gararge. Any help you coud offer will be appreciated since I am not sure what I am doing.You could contact me at anthonyrusso4@comcast.net or just send me a pm. The owner of the property has a few more mopars there - 66 dart gt, 64 dodge 500, and a few more darts of various years. Thnaks.
[Re: MECCprofessor]
#156435
11/16/09 12:50 AM
11/16/09 12:50 AM
Scott Carl
Omaha, Nebraska
Thought I'd update my progress. I did some welding and pretty much have it all wrapped up around the back glass. Just have to do the finish and paint but I won't be getting that done this season. Getting ready to put it back in storage for the winter, I have the glass in my office (Wife loves the new decoration ) I don't have a pic yet after all the welding was done but here are a few during work. Enjoy! Here is after I got the rust cut out. Interior bracing I shot undercoat in until it dripped. Should slow down that problem area at least until I die LOL
Re: Just another '74 Callenger
[Re: Scott Carl]
#156439
04/21/10 12:49 PM
04/21/10 12:49 PM
Scott Carl
Omaha, Nebraska
Just a few updates: It was a long hard winter here in the Heartland. With record snowfall, the car was inaccessible for much of the winter due to where I had it stored. Safe, dry, but totally snowed in. Well its back home now. The drive was interesting; engine seems to be getting better (rings getting freer and reseated?) but the trans won't shift into drive. Consequently, I drove the 15 or so miles from my nephew's garage to home in second gear and could only cruise 35 or 40 mph (50 or so coasting down hills;) )All guestamations as the speedo doesn't work either. Checked the kickdown linkage and it seems to be in good working order and I assume the adjustment is correct since its never been removed, so I'm going to drop the pan and maybe the valve body. Maybe so crud clogging things up. I have the BB AVS tore down to put a kit in it and drilled mounting holes to match the SB manifold. Gotta find some jets cuz I boogered one up removing it. Hey! the screwdriver worked on everything else LOL Note to self: check screw to driver match before twisting on brass jets in a 40 year old carb Also started the upholstery project. I have all but the driver's seat removed and the old covers ripped apart to use for patterns for new vinyl. WOW that was some crusty crunchey vinyl in the sun exposed areas. The piping along the back seat rest was actually fused to the parent vinyl from the years of sun beating through the back glass I couldn't get it apart without tearing up my pattern piece so I will have to "improvise, adapt, and overcome" Well its been too windy and rainy lately to get any welding done on the body so I'm mostly concentrating on mechanical stuff for now. I think I will start on the floor board(s) when I do start welding again, also entertaining the thought of frame connectors while I have the floor out, but that's another chapter...Need to rewatch some episodes of Muscle Car on Spike TV OK, in the mean time, here's some pics. Thanks for looking. This is the carb base after drilling new mounting holes:
