Re: Best E bpdy brake kit for 15" wheels [Re: brads70] #1564134
04/08/14 11:30 PM
04/08/14 11:30 PM
IN
ahy Offline
ahy  Offline
IN
On the slotted rotors... once the (modern) pads are heat cycled a few times and stop "gassing" I'm not sure how much the slots (or holes) help. For an 11.75 setup, I would personally run the better grade parts store rotors and good pads and skip the slots or holes. Spend your money on something else.
Re: Best E bpdy brake kit for 15" wheels [Re: ahy] #1564135
04/08/14 11:49 PM
04/08/14 11:49 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I agree and consider rotors a wear tear replacement item. Run them hard enough on the track and all iron rotors will crack regardless of holes, slotted/unslotted or not. Plain blank iron rotors actually have the most material on them to help dissipate heat. Just get the most cost effective ones for your performance needs and replace as necessary
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
