Alternator bracket on 70 small block #156378
11/25/08 10:30 AM
11/25/08 10:30 AM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
I've got a 1970 340 with Eddy heads. The alternator bracket wasn't original so I ordered the correct bracket, bolt and two spacers. When I tried to install it, the back of the alternator touches the head. Is this common when using Eddy heads with a stock alternator and bracketry?
thanks,
Karl
B5 Challenger T/A
Re: Alternator bracket on 70 small block [Re: KARLN] #156379
11/25/08 12:46 PM
11/25/08 12:46 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
yes very commom.
Re: Alternator bracket on 70 small block [Re: 05dakota] #156380
11/25/08 01:00 PM
11/25/08 01:00 PM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
What is the solution? Is there a bracket from another year that will give the necessary clearance from the block?
Karl
B5 Challenger T/A
Re: Alternator bracket on 70 small block [Re: KARLN] #156381
11/25/08 01:07 PM
11/25/08 01:07 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Are you using a round back style alternator? It allows a little more clearance & will usually fit, if that doesn't give you enough clearance there are kits to mount the Nippondenso Alternator...
http://chucker54.stores.yahoo.net/delialbrpk.html
Re: Alternator bracket on 70 small block [Re: 1_WILD_RT] #156382
11/25/08 02:20 PM
11/25/08 02:20 PM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
thanks for the info. I'll check tonight if I have a round back alternator. I'd prefer to go the roundback alternator route as I've already purchased the correct bracket/hardware for a 1970.
B5 Challenger T/A
Re: Alternator bracket on 70 small block [Re: KARLN] #156383
11/25/08 09:39 PM
11/25/08 09:39 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I have the same issue using my stock '69 brackets:
https://board.moparts.org/ubbthreads/show...c=1#Post4839115
The stock brackets line the alternator up perfectly with the water pump pulley but the back of the alternator hits the head.
