Re: Achieving a neutral balance: Sway bars...... [Re: ThermoQuad] #1562533
01/20/14 09:12 PM
01/20/14 09:12 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
rod end style sway bar links
I had those on the front bar on my '71 Sebring back in the '70s. Standard rubber bushings on the rear bar. Got the bars and links from Addco. They worked great with the stock front and rear springs. 318, then a 273 engines. Auto trans. The bars and such really did away with the massive lean/roll in the car.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Achieving a neutral balance: Sway bars...... [Re: amxautox] #1562534
01/20/14 10:50 PM
01/20/14 10:50 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
links
7/8 rear sway bar is large for street car
Re: Achieving a neutral balance: Sway bars...... [Re: ThermoQuad] #1562535
01/21/14 02:04 AM
01/21/14 02:04 AM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
10 ford truck end links look like a direct fit.I think it was F250 4x4 front I measured .http://www.rockauto.com/getimage/getimage.php?imagekey=2689374&imageurl=http%3A//www.rockauto.com/info/Mevotech/MS40836_FRO.jpg
Re: Achieving a neutral balance: Sway bars...... [Re: pro451bee] #1562536
01/21/14 02:59 PM
01/21/14 02:59 PM
amxautox Offline
amxautox  Offline
http://www.rockauto.com/getimage/getimag...MS40836_FRO.jpg
fixed
Tom
author unknown
Re: Achieving a neutral balance: Sway bars...... [Re: amxautox] #1562537
01/22/14 03:19 AM
01/22/14 03:19 AM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
Ya those are the ones , heavy duty too.Very cheap too
Re: Achieving a neutral balance: Sway bars...... [Re: pro451bee] #1562538
01/22/14 04:02 AM
01/22/14 04:02 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Anybody have a measurement on the Ford ones? My car needs around a 4.5" length.
Mopar to the bone!!!
Re: Achieving a neutral balance: Sway bars...... [Re: amxautox] #1562539
01/22/14 11:28 PM
01/22/14 11:28 PM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
Hmmmm.....
Interesting!
Re: Achieving a neutral balance: Sway bars...... [Re: Kern Dog] #1562540
07/06/14 03:22 AM
07/06/14 03:22 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Sorry that I never responded with an update. Recently there was a thread in the General forum where the OP politely asked members to essentially "close the door" once the subject they asked of had been resolved.
I took Feets advice first and checked tire pressures. I was at 26-28 lbs up front and close to 30 in the rear tires. The sidewalls are pretty short and it can be hard to tell by looking when they are a few lbs low. I set pressures to 36fr & 32rr. The car felt more responsive to steering input but still felt like the rear wanted to come around. I replaced the urethane rear end link bushings with rubber and drove the car again. I think I've found a workable setup for now. It feels neutral when coasting, braking or with light throttle. It will still get tail happy when I lean into the throttle which is fine by me.
Thanks for the guidance, Greg
Re: Achieving a neutral balance: Sway bars...... [Re: Kern Dog] #1562541
07/06/14 02:19 PM
07/06/14 02:19 PM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
Yes the "followup" thread had a lot of merit. Glad to see if has already had some positive results here and elsewhere.
Not sure I would have been as gentle ,nor had the same responses on that topic
I do think one thing that steers people away from followups, is the perception that comments after the fact are hostile, critical, and or un complimentary, and few are inspired to subject themselves to that, understandably.
I'm glad you found a solution you are comfortable with.
I forbid my content here from being learned and used by artificial intelligence systems.
