Re: welder feedback [Re: Danan] #156112
11/26/08 02:13 PM
11/26/08 02:13 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Buy the biggest welder you can afford with the money you can spend.
The difference between a 110v and even the 175/180 class 220v machines is huge. There's MUCH more to a welder than the material thickness it's capable of welding.
The ONLY reasons IMHO to buy a 110v machine are 1) cash 2) portability 3) lack of 220v service. Service is easy to put in. Portability isn't a big deal unless you plan on dragging it to friends to weld. Cash is the biggest issue.
You can find a complete 1-3 yo Miller 175/180 with tank/cart and occasionally helmet for around 450-750. Just have to look. Craigslist is a good place to start. There's a Lincoln 250 in Tulsa for $700
And the comment about it's just for this... never works out the way... You'll end up doing other projects that require more oooomph. DAMHIK!
Re: welder feedback [Re: RobX4406] #156113
11/26/08 07:27 PM
11/26/08 07:27 PM
Irving, TX
feets Online tonguue
Senior Management
feets  Online Tonguue
Senior Management
Irving, TX
I've had the Lincoln 3200HD and two 140s. Stinkin thieves!
I really like them and never had a need for anything larger. I've easily welded everything from sheet metal to 1/4" without ever saying "I wish I had a bigger welder."
The portability is a biggie. I've hauled it around to several different places (stolen from two other homes ) to use it for structural steel and building the off road buggy amongst other things.
Unless you get into something really crazy, I doubt you'll out grow one of these. If you do, save your pennies as best you can and get a SECOND welder. That way you've still got one that can be used wherever you go.
I've seen some guys break important stuff on their cars at the track. They needed a welder. If they had the 110V unit, they could have powered it off a generator and fixed their ride.
You can do a bunch with the little $400 units. More than most people think.
However, if you decide to build ocean-going container ships or multi-lane freeway bridges, something larger would be handy.
- Stu Harmon
Re: welder feedback [Re: feets] #156114
11/26/08 07:36 PM
11/26/08 07:36 PM
L.I. N.Y. Hemi Street
HemiGreg Offline
HemiGreg  Offline
even though its not the question get a Miller mig 140.
they die hard and run anywhere.
ive had them all and i mean in ###
and the miller is the only one still going and my 10 yr old nephew said it was the easyiest to run too.
yea i got a Miller Syncrowave tooo so i can compare to the best.
Re: welder feedback [Re: moparpollack] #156115
11/26/08 09:19 PM
11/26/08 09:19 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
OK, I'm going to throw this out there because I've had a good experience with mine:
Clarke 180EN 220V/180A MIG
I searched for several months to find a used Miller, since there's a Miller store not far from me. Not sure what was going on, but you couldn't touch a used 110V unit for less than $700 back then (6-7 yrs ago), and I really wanted a 220V for the extra flexibility. I finally got to where I NEEDED a welder for my LCA project and couldn't find the Miller I wanted, I bit the bullet and ordered the Clarke. I got it delivered in 3 or 4 days for about $560, including the cart, autodark helmet & regulator. FWIW, the cart is functional, but a PO$, and would make a good project if you have the time. I also ordered a small pile of consumables, but most TWECO-style gun parts will fit.
I wired my garage with a single 220V outlet near the door, and made up a 15-20' heavy extension cord so I could reach anywhere in the garage and most anywhere under the carport. So far, I've made an engine cradle, a set of boxled LCA's, subframe connectors, torque boxes, and a number of small engine accessory brackets. The unit has worked perfectly, with the only problems I have ever seen related to me forgetting to turn the gas on (snap-crackle-pop), forgetting to turn it off (empty tank - again!), and wire so old it gets crud on it and doesn't push well. Those have all been easy fixes. Some day I hope to have time to weld more often and avoid all three situations.
Is the Clarke a great welder? Probably not. It doesn't have the infinite power/feed adjustments that other higher-dollar units have, but it seems (to this rank amateur) to do the job I need it to do. I've called their tech support (in OHIO) a few times for questions about how to weld or what to do, and they've always been helpful. For me, it was - and is - a great "starter" welder, and should last me a long time given the limited amount of welding I do.
Clair
