Re: 71 challenger convertible
[Re: Stewpar]
#1560901
01/09/14 04:52 AM
01/09/14 04:52 AM
Posts: 29,657 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Compare notes on what plant the cars were built at........
All Challenger (& Barracuda) convertibles were built at Hamtramck.
[Re: Alaskan_TA]
#1560902
01/09/14 05:07 AM
01/09/14 05:07 AM
Posts: 4,848 Memphis
HemiRick
Memphis
My Chall vert also has 2 per side. built 9/69 I asked about this before on this board and was told it was normal but dont remember the reason.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#1560903
01/09/14 12:52 PM
01/09/14 12:52 PM
Posts: 4,105 Horsham, Pa.
Finoke
Horsham, Pa.
My 70 Challenger vert also has two sets. Built 9/02 69. I agree, it sounds like a Challenger vert only thing.
[Re: fbernard]
#1560905
01/09/14 09:45 PM
01/09/14 09:45 PM
Posts: 521 Virginia
larry4406
Virginia
I have the same thing on my car, and I too think it's a way to catch up the 2 inches differences between Challenger and cuda. Besides, the same thing goes for the seat belt bolts (additional brackets welded 2 inches forward from the "normal one") :
The OP has the same seat belt bracket welded on as you yet his belt is attached to the rear most hole.
[Re: larry4406]
#1560906
01/09/14 10:00 PM
01/09/14 10:00 PM
Posts: 403 30 miles west of EuroDisney
fbernard
Saw that. Mine was attached to the front hole.
Funy things about these parts is that OEM hardtop parts are welded most professionally, whereas the convertible parts are put together in a quite sloppy fashion.
I'd like to know at which point on the assembly line convertibles started to differ from the hardtops. At least the workers didn't have to hammer the wheelhouses flat like they did on ragtop Mustangs...
[Re: 62BT409]
#1560912
01/11/14 05:22 PM
01/11/14 05:22 PM
Posts: 1,240 Saline, MI
efisixpack
Saline, MI
Mine has two on each side as well. Built 5-28-71. Obviously a late build.
When I die I want to go like my Grandfather did, quietly in his sleep. Not screaming like the passengers in his car.
[Re: Convertcuda]
#1560914
01/14/14 05:37 PM
01/14/14 05:37 PM
fbernard
Challenger and Cuda convertibles may look similar but there are great differences in the convertible sheet metal structure.
Not sure about what you mean by "sheet metal" here. Do you mean the convertible top assembly is different between a Challenger and a cuda?
[Re: daveh1971]
#1560916
01/15/14 07:30 PM
01/15/14 07:30 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Mine is a 10/69 and it has two and the belts are in the rear mount holes
Founder and CEO of the Central Valley Mopar Drag Pack
