Does Anyone Make Sway Bar Tabs For Controll Arms?
#1560696
01/08/14 07:09 AM
01/08/14 07:09 AM
Posts: 157 Santa Rosa CA
Bones
Santa Rosa CA
Does anyone out there make sway bar tabs for welding onto 73-76 A-Body lower control arms? I have access to a metal shop and could probably fab up a set but if someone already makes them it would save me some time.
Do not hug a man holding a wrench in his hand.
Re: Does Anyone Make Sway Bar Tabs For Controll Arms?
[Re: Andrewh]
#1560698
01/08/14 02:24 PM
01/08/14 02:24 PM
Posts: 12,589 Sacramento, CA
cal_gecko
Sacramento, CA
hotchkis and firm feel I think both make them.
another company makes one that mounts to the shock bolt instead of having to weld as well, but I can't remember who that is.
Hmm.. very curious about this
[Re: Andrewh]
#1560700
01/08/14 05:15 PM
01/08/14 05:15 PM
Bones
Santa Rosa CA
I see them sold as part of their front sway bar set but don't see them sold on their own. Can anyone direct me to a set sold on their own without the kit?
[Re: Bones]
#1560701
01/08/14 06:22 PM
01/08/14 06:22 PM
Posts: 27,485 So Cal
autoxcuda
So Cal
Hotchkis sells them seperatly. Go to their website. And they a thicker than stock too.
[Re: Andrewh]
#1560703
01/08/14 09:43 PM
01/08/14 09:43 PM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
Hellwig bar for my 68 Charger came with the tabs that bolt to the lower shock bolt
[Re: autoxcuda]
#1560704
01/09/14 01:53 PM
01/09/14 01:53 PM
Posts: 460 Oklahoma
VoodooCLD
Oklahoma
That would have been nice to know after i welded one of them on upside down ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: autoxcuda]
#1560706
01/10/14 06:36 PM
01/10/14 06:36 PM
Bones
Santa Rosa CA
I called the Hotchkis sales department and was told that they are not usually sold separately. The guy took my email info and said he would talk to his manager about putting them in the computer so he could sell me a pair separately from the sway bar kit. Hopefully he will get back to me.
[Re: Bones]
#1560707
01/10/14 07:02 PM
01/10/14 07:02 PM
Posts: 460 Oklahoma
VoodooCLD
Oklahoma
I'm pretty sure i ordered mine separate from my sway bar kit. Only problem was they only sold them in pairs. So i ended up buying a whole other set when i welded one upside down. I don't think building a car is expensive, building it twice due to my own stupidity is expensive ![](/ubbthreads/images/graemlins/smile.gif)
[Re: Bones]
#1560708
01/10/14 07:06 PM
01/10/14 07:06 PM
Posts: 5,366 Rancho Cordova, California (Sa...
hemi71x
Bones: I haven't a clue why your having such a heartburn in getting sway bar mount tabs direct from Hotchkis. You asked me that question over on ebay, through the "ask the seller a question" in regards to the rebilt lower control arms that i rebuild, then resell. I told you that i get tabs from Hotchkis direct. Summit sells them, along with numerous other automotive warehouses, that sell Hotchkis products. What you want is #233367 They are $45.00 a pair, from Hotchkis themselves. I have bought lots of them for my LCA rebuilding. Jim V. hemi71x
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: convx4]
#1560713
01/20/14 10:51 PM
01/20/14 10:51 PM
hemi71x
I believe that all the ones for sale are for b-bodys, Not A-bodys.
I would like to know the measurements for the a-bodys. Can any one help?
The op is asking about 73-76 A body sway bar mount tabs. Hotchkis repops those. In your picture, you have 65-72 LCA's with those sway bar mount tabs on them. In that regard you are correct, Hotchkis DOES NOT reproduce them. They repop brackets for the 66-69 B Body line of cars. And they repop brackets for the 73-76 A bodys, and 70-72 B bodys, 70-74 E bodys, which all are the same bracket. That should put clarification to this topic.
[Re: convx4]
#1560715
01/27/14 01:26 AM
01/27/14 01:26 AM
Posts: 18,686 Fresno, CA
Jim_Lusk
Fresno, CA
well I didn't get a response to the measurements so I just made them up. What do you think.
They look great, BUT get the sway bar bolted onto the k-member and attach the tabs to the bar with the end links. Put the weight of the car on the tires to locate the tabs properly.
