Re: sub frame connertors
[Re: Dons Dart]
#1560450
01/08/14 02:53 PM
01/08/14 02:53 PM
Posts: 7,798 Lyons, CO
MileHighDart
Lyons, CO
Just because the car is on stands, doesn't mean the suspension cant be "loaded". It depends on where you place the stands.
When I welded mine in. I ran the front of the car up on ramps, then jacked the rear up and set it on stands, with the stands place under the rear end housing. This way the car is up in the air and you can work under it, but it is setting on the suspension, just as if it were sitting on the ground. Hope that helps a little. I think some people are thinking that "on stands" means you have them placed under the unibody, with the suspension hanging.
[Re: MileHighDart]
#1560451
01/08/14 03:45 PM
01/08/14 03:45 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
Mine are 1-5/8 c.m. round tube all tied in from the cage above.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Dons Dart]
#1560454
01/08/14 04:55 PM
01/08/14 04:55 PM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
I used the bolt in style but welded them right off the bat. I didn't want to cut through the floor. I just wanted to stiffen it up, I don't plan on any wheelstands.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
[Re: MileHighDart]
#1560457
01/08/14 05:27 PM
01/08/14 05:27 PM
Posts: 2,757 Gilbertsville, PA 19525
Pntastar69
Here is your answer.
