I have a 360 magnum and I'm running a quick fuel super street series 680 cfm vs carburetor on a dual plane edelbrock rpm air-gap intake manifold and a 1 inch 4 hole phenilic carb spacer.
Over the last couple days I noticed my idle was starting to get rough, so today I decided to try and see if I could figure out why, I go to put my vaccum gauge on the manifold vaccum port on the carburetor and there is fuel on the rubber nipple covers. So I tightend down my fuel bowl screws a little tighter.
Then I went to see if it was running right and it wasn't, it accually felt worse, The only thing I can think of is the fuel that was leaking must have hit my carburetor base gasket and it broke the seal, Is this possible? is my thinking correct? Because if it's not then I have no clue as to whats going with it.
