Re: What tool do you use for cylinder head porting? [Re: bonefish] #1560243
01/07/14 03:51 PM
01/07/14 03:51 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
i use a tool called a Dwayne Porter.(no, im not callin Dwayne a TOOL)
I recall when Dwayne referred to another ex-Moparts engine "guru" as a "flaming tool bag", though. /
Re: What tool do you use for cylinder head porting? [Re: dwayne welder] #1560244
01/07/14 03:59 PM
01/07/14 03:59 PM
BradH Offline
BradH  Offline
Electric & air here, too:
1. Most of the head & intake work I do is using a Makita grinder w/ a cheap dimmer switch to allow some RPM control.
2. I have a decades-old Mac Tools air grinder that I've done some head porting with, plus it was handier to use the air grinder when I was doing casting cleanup and throw profiling on my Eagle crank last year.
3. I have a couple of 1/8"-stem carbide burs that are good for doing certain detail work using a Dremel (either on the grinder or w/ the optional shaft extension).
Re: What tool do you use for cylinder head porting? [Re: BradH] #1560245
01/07/14 06:50 PM
01/07/14 06:50 PM
warren, mich.
dwayne welder Offline
warren, mich.
Hello again; I forgot to mention that my air die grinders are "DOTCO'S" the best!!! There are a little pricey, but last a long time! I have an oiler set up on that air line for them. It help's lubercate them! I have had three grinder's since 1999, and never had them rebuilt!! Still going strong!!
Re: What tool do you use for cylinder head porting? [Re: dwayne welder] #1560246
01/07/14 08:30 PM
01/07/14 08:30 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Another from the bullet.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
