Re: Wild vid of my duster., Cal tracs dont work.
[Re: sdaurity]
#1558220
01/03/14 05:27 PM
01/03/14 05:27 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Nice. Sounds like you want to really have some fun. Congrats and great luck.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: mokid]
#1558222
01/03/14 05:50 PM
01/03/14 05:50 PM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
Cracked the trans pan, tweaked the front upper shock mount. I had it right back out the next weekend. I knew it would happen eventually racing no bar classes so I did some extra bracing/bump stops etc to try my best to minimize any damage when it did happen.
One day I will have something cool here.
[Re: sdaurity]
#1558223
01/03/14 06:19 PM
01/03/14 06:19 PM
Posts: 252 St.Louis, Mo.
mokid
St.Louis, Mo.
Yes bent strut arms, bent new oil pan, cracked new trans-pan, my entire steering column broke of brackets and was sitting on my lap, luckly was able to pull it up and streer the car of track, we start hitting launch RPMs harder 4700 and getting chassis to work and man did it.
[Re: sdaurity]
#1558224
01/03/14 06:51 PM
01/03/14 06:51 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Damn I wish this car wasn't being sold, I'd love to see what you could do with it all dialed in. Oh well, I've seen your reason for selling and I can't say I blame you. GLWS!!
What did you see? I wasn't going to post pics of my new stuff so I didn't get burned at the stake here.
You didn't have to let the cat out of the bag! I meant I've seen your reason, the reason I saw was you wanted to put money into your business.
If I was sitting better that duster would be mine no questions asked. . PS you aren't the only one working on a chevystang lol
[Re: John Burdine]
#1558229
01/04/14 10:40 AM
01/04/14 10:40 AM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
no doubt they work, I've went 1.27 60 with 22" front segment and Rancho 9-way shocks on a 315 tire.
![](/ubbthreads/images/graemlins/iagree.gif) Evidently the setup wasn't right, track was apparently overpowered and the video shows the result. ![](/ubbthreads/images/graemlins/Twocents.gif)
Nice car though... ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: actionange]
#1558230
01/04/14 11:09 AM
01/04/14 11:09 AM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
Drad radials on a track prepped for them is a total diff animal then slicks for sure.I know travel has been discussed on moparts before,but with these type cars less is better. There's really not much to do if you dont have enough weight in the nose or a Davis traction device, and in Stephen's defense this happenes to the Best drivers out there.My friend Dean bought 90lbs of ankle weights at the yellow bullet event 2 yrs ago and wrapped them in maskin tape around the front of his frame.This is an easy fix with slicks and as simple as adding more power off the hit,to get a little tire spin. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: fishy340]
#1558231
01/04/14 11:12 AM
01/04/14 11:12 AM
sdaurity
North Cackilacky
I had 80 lbs on the nose that pass. That was only like the 4th pass on the car with nitrous so I really had no idea what was about to happen.
