Page 2 of 3 1 2 3
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1557007
01/02/14 05:44 PM
01/02/14 05:44 PM
The Great White North
RAMM Online happy
RAMM  Online Happy
I too am very curious on the price point and how long these take to machine. Brian, What machine are you using? Also-Will this program fit into an EQ casting? J.Rob
I can only give you a price if you let me help with your next EM build
You know, I never thought of that but I'd have to sonic the floor/short turn on the EQ heads to see...maybe? These don't take too long because it's only the intake port.
They're done on a Rottler machine.
I would gladly accept some help but our engine for this year is pretty well done. Roughly how long for the 4 intake ports? What method did you use for the digitizing? J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: CNC Ported Iron heads [Re: RAMM] #1557008
01/02/14 07:43 PM
01/02/14 07:43 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Brian, if you'd like some EQ guienna pigs, I have a pair ready to ship. Uh umm, cough, cough...
Seriously, I'd be curious of the pricing with your VJ and valves, if the program was applicable to the EQ's
Re: CNC Ported Iron heads [Re: cudadoug] #1557009
01/02/14 08:43 PM
01/02/14 08:43 PM
SoCal
Brian Hafliger Offline OP
SoCal
If you want to send them down, I'll sonic test them and then go from there. I might be able to have EQ send me a head to test...I'll let you know.
Brian Hafliger
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1557010
01/02/14 10:17 PM
01/02/14 10:17 PM
cudadoug Offline
cudadoug  Offline
PM-ed ya to not clutter up this thread...
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1557011
01/03/14 06:23 AM
01/03/14 06:23 AM
Washington
skrews Offline
skrews  Offline
Washington
Intake MCA is 2.200 at the pinch.
Intake port poured right at 200cc.
Re: CNC Ported Iron heads [Re: skrews] #1557012
01/03/14 12:26 PM
01/03/14 12:26 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Thas kind of big.
Mine is 185cc with some more flow but stalls earlier.
Is there enough material around the guide to install new guides after the porting?
Still no price?
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1557013
01/03/14 01:22 PM
01/03/14 01:22 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Thanks.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: CNC Ported Iron heads [Re: sshemi] #1557014
01/03/14 04:08 PM
01/03/14 04:08 PM
SoCal
SoCal
Thas kind of big.
Still no price?
I can't price on here...they won't let me
Yes you can put guide liners in or use a shorter guide. I can get more flow earlier too, as much as 15 cfm at .400 and 10 more at .500 but the port is noiser and stalls real bad...Flow is only part of the puzzle...air speed, port shape, CSA is very important and it's really a balancing act of all 'dem.
Brian Hafliger
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1557015
01/03/14 04:22 PM
01/03/14 04:22 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
Could this be done to a set of "J" heads? Would it be cost effective to install 2.02's and have a set CNC'd? Just curious
Re: CNC Ported Iron heads [Re: SLOW67] #1557016
01/03/14 04:26 PM
01/03/14 04:26 PM
SoCal
SoCal
No, it's a totally different port design. Not sure if a cnc program for stock heads would be a big seller because of the cost factor....
Brian Hafliger
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1557017
01/03/14 04:37 PM
01/03/14 04:37 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Working on some eddy port programs next
What E-head stuff are you looking to develop CNC programs for?
Re: CNC Ported Iron heads [Re: BradH] #1557018
01/03/14 06:10 PM
01/03/14 06:10 PM
SoCal
SoCal
SB right now...I might look at the Victor BB stuff since I have a head but the STD port version seems like a waste of time since everyone's building large cid engines these days....
Brian Hafliger
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1557019
01/03/14 07:16 PM
01/03/14 07:16 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Since I have a new set of the EQs on the shelf, I would be very interested in this as well!
Re: CNC Ported Iron heads [Re: Jwilli500] #1557020
01/03/14 07:57 PM
01/03/14 07:57 PM
sweden
sshemi Offline
sshemi  Offline
sweden
So can you pm me the prize?
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1557021
01/03/14 08:26 PM
01/03/14 08:26 PM
Finland
mopster Offline
mopster  Offline
Finland
2.200 pinch canīt support those flow numbers, should be 2.300. Anyway, these could be great heads for 408 with hp peak at 5900, or 360 with hp peak at 6700.
Re: CNC Ported Iron heads [Re: mopster] #1557022
01/03/14 09:04 PM
01/03/14 09:04 PM
SoCal
SoCal
146cfm times 2.200 = 321 theoretical max flow...it will and does support those flow #'s.
Brian Hafliger
Re: CNC Ported Iron heads [Re: mopster] #1557023
01/03/14 09:06 PM
01/03/14 09:06 PM
FastOne Offline
FastOne  Offline
what manifold will you be using on the 392?,or is that undecided at the moment
Re: CNC Ported Iron heads [Re: Brian Hafliger] #1557024
01/03/14 09:24 PM
01/03/14 09:24 PM
Finland
mopster Offline
mopster  Offline
Finland
You are referring to 350 fps air speed but that works only in local areas. Average air speed canīt be over 311 fps or port will be choked.
Re: CNC Ported Iron heads [Re: mopster] #1557025
01/03/14 10:51 PM
01/03/14 10:51 PM
SoCal
SoCal
Anything over 350fps is not too good...that's the standard!
Brian Hafliger
Re: CNC Ported Iron heads [Re: FastOne] #1557026
01/04/14 01:32 AM
01/04/14 01:32 AM
SoCal
SoCal
We'll be testing 4 different intakes!
Brian Hafliger
Page 2 of 3 1 2 3
