Re: CNC Ported Iron heads
[Re: Brian Hafliger]
#1556990
12/31/13 09:10 PM
12/31/13 09:10 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
.100 68 .200 142 .300 201 .400 249 .500 281 .550 290 .600 296 .650 293 .700 294
28" on a 4.030 bore...4.125 bore added 3 cfm at .500 and 4 cfm at .600 and then went backwards but still flowed 295 cfm at .650 lift. Brian
Brian Hafliger
#1556991
12/31/13 09:34 PM
12/31/13 09:34 PM
Posts: 7,506 Az
Crizila
Az
Looks great Brian and the flow numbers are awesome. Mopar Magnums or aftermarket?
Fastest 300
#1556993
12/31/13 09:46 PM
12/31/13 09:46 PM
Posts: 7,506 Az
Crizila
Az
Got a CnC program for the exhaust side too?
Fastest 300
[Re: FastOne]
#1556999
01/01/14 03:13 AM
01/01/14 03:13 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Looks good, what does the air speed sound like on the flow bench?, just right, slow, fast, coarse, manometer staying steady, think you know what I mean
Port is very stead up to .600 and then is a bit up and down, not horrible though. Port is pretty smooth actually, very balanced port design
At .700 lift it's not too bad either...just at .630 to .680 it's a bit rough. I can't shape the short turn any better due to water close by.
I'm putting a set on a 392 short block soon with 13:1 and a solid roller so we'll see what she does
Brian Hafliger
#1557000
01/01/14 03:24 AM
01/01/14 03:24 AM
Posts: 20,200 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Did you happen to check runner cc?
[Re: sshemi]
#1557003
01/01/14 06:26 PM
01/01/14 06:26 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Just as the eddy heads are not a full on race head, neither are these! I'll have all the info you guys want tomorrow nite. I'm off today and going to enjoy my family. No matter what they cost, they will always be cheaper than ANY other aluminum head out there and they will hold their own...I hope we shall see. Cost as always will be much cheaper than anything else out there making similar power with better components!!
Brian Hafliger
#1557004
01/02/14 10:57 AM
01/02/14 10:57 AM
Posts: 1,051 The Great White North
RAMM
I too am very curious on the price point and how long these take to machine. Brian, What machine are you using? Also-Will this program fit into an EQ casting? J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
#1557006
01/02/14 05:37 PM
01/02/14 05:37 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Intake MCA is 2.200 at the pinch.
Intake port poured right at 200cc.
Brian Hafliger
