Re: Is 380 mm rotors large enough for you?
[Re: OzHemi]
#1556687
04/13/14 01:11 AM
04/13/14 01:11 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Yep, but for 225 per caliper, I think they are still a steal of a deal!
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1556688
04/14/14 03:52 PM
04/14/14 03:52 PM
astjp2
Utah and Alaska
Well Brembo does not sell service parts for OEM calipers and Mopar only sells the bridge bolt with the calipers. So I called Ford, they list the anti Rattle kit for the 2013 GT500 as a 2b164 part number, I ordered a kit for $31.00, so I hope it comes with the bolt. Tim
[Re: astjp2]
#1556689
04/16/14 08:16 PM
04/16/14 08:16 PM
astjp2
Utah and Alaska
The kit from Ford had the bridge bolt, I will have pics when I get home. Now to make adapters once I finish drilling the rotors. Tim
[Re: OzHemi]
#1556691
04/16/14 11:59 PM
04/16/14 11:59 PM
astjp2
Utah and Alaska
Its kinda disappointing that Mopar doesnt support their products better!
[Re: astjp2]
#1556692
04/17/14 01:00 PM
04/17/14 01:00 PM
Posts: 256 USA
Consulier
USA
Is the GT500 the same caliper? Also, what's the full part number? This is what I found with that extension... No Bolt
[Re: astjp2]
#1556693
04/17/14 07:47 PM
04/17/14 07:47 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I'd make my own bridge and call it good. Once you get the calipers installed you need to do something about those girlie sized feet.
[Re: astjp2]
#1556694
04/17/14 08:15 PM
04/17/14 08:15 PM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
6 each 40 mm pistons, they are all the same size!
I missed it? What are these off of?
[Re: brads70]
#1556695
04/18/14 03:52 PM
04/18/14 03:52 PM
astjp2
Utah and Alaska
The GT500 is supposed to be the same caliper, they are made for the OEM's and are not the same as the GT6 series calipers. I got one for a 2013 SRT8 Grand Cherokee. They are listed on Ebay for about 300 each. The Ford Part number is DR3Z-2B164-A for the anti rattle clips and bridge bolt. For 32.00, I could not build the bridge bolt, considering my time. Since my lathe is down, it is more of a pain than its worth. I still have to drill the rotors, I should see how the mustang rotors fit compared to the GC rotors. Projects like this get expensive if I start buying parts just to see if they fit. Tim
Well the rotors are thinner on the GT500, the bridgebolt is too short...by about 3/8", but at least now I have a pattern to work from...crap, another 30.00 wasted unless I modify the bolt I have and making it work. Tim
[Re: astjp2]
#1556696
04/18/14 04:11 PM
04/18/14 04:11 PM
Posts: 256 USA
Consulier
USA
I usually use Rock Auto or one of the other sites only to get some basic dimensions.
GT 500 Rotor
[Re: astjp2]
#1556698
04/18/14 04:15 PM
04/18/14 04:15 PM
astjp2
Utah and Alaska
Yep, too short, maybe I can make a bushing and open up the recessed area and make it work. Tim
[Re: OzHemi]
#1556701
04/20/14 04:28 AM
04/20/14 04:28 AM
astjp2
Utah and Alaska
Here is the info on the Jag XKZ Descripition:
UPC: 018575357276
Style: Full Cast
Bolt Circle (in): 4.252
Bolt Circle (mm): 108.00
Overall Height (in): 1.890
Overall Height (mm): 48
Outside Diameter (in): 14.961
Outside Diameter (mm): 380
H&R / R: Disc Only
Solid or Vented: Vented
Nom Thk (in): 1.417
Nom Thk (mm): 36.00
Min Thk (in): 1.34
Min Thk (mm): 34.00
No. of Stud Holes: 5
Stud Supplied (in): No
[Re: astjp2]
#1556702
04/21/14 09:52 PM
04/21/14 09:52 PM
astjp2
Utah and Alaska
Well unless someone from here is willing to provide some technical support, I am starting to lose interest for now on this project. I feel that I am not making much progress on finding wheels to fit our older cars with big brake kits that dont cost a fortune. I enjoy projects like this but my resources are running dry...Tim
[Re: astjp2]
#1556703
04/21/14 10:52 PM
04/21/14 10:52 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
American Muscle sells affordable wheels in 19" sizes in 5-4.5 patterns.
Mopar to the bone!!!
