Re: Is 380 mm rotors large enough for you?
[Re: astjp2]
#1556665
03/31/14 04:34 AM
03/31/14 04:34 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
This was expensive...the blair company only sells replacements in quantities of 3...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: brads70]
#1556667
03/31/14 02:44 PM
03/31/14 02:44 PM
astjp2
Utah and Alaska
They walk and create oversize holes, this way, they are bored and stay round. I just let the drill get cocked and the cutter snapped like a twig.
[Re: feets]
#1556670
03/31/14 06:25 PM
03/31/14 06:25 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Might be easier to just find a local wheel repair/modify place and have them toss the rotors in their mill or what ever they use to redrill wheels and get it done in a few minutes. My wheel guy drilled my rotors out...took me longer to drive there and back to pick them up then to have them done. (in hindsight, I should have drilled my hubs to Mercedes bolt pattern and have the wheels drilled the same, save having to modify the rotors..but oh well. )
[Re: OzHemi]
#1556671
04/01/14 08:25 AM
04/01/14 08:25 AM
Posts: 294 The Netherlands, OV
dickdale
The Netherlands, OV
If you do that then you must change the rear aswell. Best thing to do is adjust the MB rotors by going to a machine shop and let them dril the holes. Bring the hubs also so they can adjust the center hole on a lathe...
[Re: dickdale]
#1556673
04/01/14 01:10 PM
04/01/14 01:10 PM
OzHemi
Garden Grove, CA
Wouldn't have been any need to change the rear really in my case at least. It is not like I would ever rotate the wheels, so different bolt patterns wouldn't have really mattered. (I run 8" wheels up front and 10.5" in the rear. )
Either way, it's no big deal to get the front rotors redrilled in my case when I happen to need to change them.
[Re: feets]
#1556675
04/02/14 01:00 AM
04/02/14 01:00 AM
astjp2
Utah and Alaska
My lathe is not up and running nor is my mill, both are getting a full rebuild and rescraping. I can hold a .005 tolerance with the tooling I have made. Tim
[Re: feets]
#1556677
04/03/14 06:39 AM
04/03/14 06:39 AM
astjp2
Utah and Alaska
One was given to me in pieces and the other was one that I bought and in the process of rebuilding. The lathe is a 11x36 Rockwell from 1957, the mill is a mid 1970's to late 1980's 6x26 from tiawan. I need to scrape both in and then I can start using them. I am waiting on a few parts for the lathe, a couple of gears, belts and then what ever I find in the varidrive that is not working and need to fix. Its just time and money! tim
[Re: astjp2]
#1556678
04/12/14 05:15 PM
04/12/14 05:15 PM
astjp2
Utah and Alaska
Well I came up with enough for 1 caliper, this thing is frikn huge! I am wondering what the hole at the top of the caliper is for? That is a size 11 foot to compare it to!
[Re: astjp2]
#1556679
04/12/14 05:16 PM
04/12/14 05:16 PM
astjp2
Utah and Alaska
6 each 40 mm pistons, they are all the same size!
[Re: OzHemi]
#1556681
04/12/14 10:19 PM
04/12/14 10:19 PM
astjp2
Utah and Alaska
The pictures online show a special bolt, now where I am going to find one of those? They are not on the dealership listing....
[Re: astjp2]
#1556682
04/12/14 11:14 PM
04/12/14 11:14 PM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
I agree the hole is for a bridge spacer and bolt. I'd just use a socket head capscrew and a tube spacer (simple lathe job) if you can't find the proper parts.
[Re: OzHemi]
#1556684
04/13/14 12:40 AM
04/13/14 12:40 AM
astjp2
Utah and Alaska
These are a stretch bolt for this caliper, I have seen them used on aircraft before. This is what I need....
