Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS.................
[Re: 1967dartgt]
#1555824
03/04/14 01:06 AM
03/04/14 01:06 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I am sure you saw gups pic of his rear suspension, so I am by no means the inventor of this idea. His car has been that way as long as I have know it. I just copy other people good ideas.lol
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Thumperdart]
#1555826
03/04/14 08:16 AM
03/04/14 08:16 AM
Posts: 6,151 Melbourne , Australia
LA360
There have been some posts on the Bullet from some of the heavy hitters in the small tire leaf spring classes. These guys had run the shock behind, or in front of the housing. Their shock data was smoother with the shock mounted in the front (rear mounted the graph would spike) and the car was quicket and more consistant.
Alan Jones
[Re: Thumperdart]
#1555828
03/04/14 04:37 PM
03/04/14 04:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The car is being lifted at the same point which is the front of the spring at the bolt hole... with a shock on the rear it will see a farther travel than if its in front.... its a matter of what the shock likes that makes the difference... its pushing oil through a set of holes... now does it like the pressure of the oil to be higher(with the shock in the rear) or with the pressure to be lower(with the shock in front).. the higher and lower pressure is from the distance that the piston travels in the shock(its mounted on the shaft)... not all shocks are equal.. when I took the Dave chassis seminar he spoke alot on shocks and how some react to different inputs ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Thumperdart]
#1555831
03/05/14 05:13 PM
03/05/14 05:13 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I will fit mine in front of the axle because it's mounted an inch further back, so it will straighten the shocks up both ways. It's got to be at least 6" forward with the spring clamps reversed. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#1555832
03/10/14 05:16 PM
03/10/14 05:16 PM
deaks
robin hood country
I have fitted my shocks the same as 67 dart GT and at rest there's only 3/4" compression, that is without me. I have only tacked the upper plates at the moment, so i can break the welds but the trunk floor curves down near the top of the shocks so either i need to cut the floor and remake that section, hammer it upwards,change my 1-1/2 lowering blocks for 2" ones, or cut the bottom bolt off the plate and fab something onto it to make it hang lower. Any suggestions ?
[Re: 1967dartgt]
#1555834
03/10/14 05:39 PM
03/10/14 05:39 PM
deaks
robin hood country
They are afco doubles, i'm not buying another set. How much travel have you got at rest ? Mick
[Re: 1967dartgt]
#1555837
03/10/14 07:30 PM
03/10/14 07:30 PM
deaks
robin hood country
Pushing the tube up into the chassis doesn't increase the height much, maybe my afcos were a little short in the first place. I'll probably lower the bottom mount an inch. Mick
[Re: deaks]
#1555838
03/10/14 08:24 PM
03/10/14 08:24 PM
1967dartgt
Hilltown Pa
What are you using for lower mount?
[Re: 1967dartgt]
#1555839
03/10/14 08:40 PM
03/10/14 08:40 PM
deaks
robin hood country
The stock mount for the SS springs.
