Page 5 of 8 1 2 3 4 5 6 7 8
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555801
03/02/14 05:46 PM
03/02/14 05:46 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555802
03/02/14 06:29 PM
03/02/14 06:29 PM
State of confusion
Thumperdart Offline OP
State of confusion
Really depends on what springs you have. The ride height can change a lot from car to car. Best to measure extended length and length with weight on car.
Did you change the i/c on your Dart by moving the ft. mounting point or are you still in the stock location.
My springs are mounted as high as I can get them in the pocket you can go. I have a 1/8 of a inch to the floor pan from the spring eye.
This is what I needed to hear and I`m slammin mine back up where they were before I screwed em up.............
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555803
03/02/14 06:48 PM
03/02/14 06:48 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Are the caltrac mounts similar to the stock ones.
Have you managed to maintain your comp damping by pushing the upper mounts up ?
Thanks for the pics.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: deaks] #1555804
03/02/14 09:38 PM
03/02/14 09:38 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Mick
It's a little shorter but I still have plenty of travel. The Calvert shocks plates are the same as factory but are thicker and use a bolt for the shock mount not the stud.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555805
03/02/14 11:46 PM
03/02/14 11:46 PM
State of confusion
State of confusion
Mick
It's a little shorter but I still have plenty of travel. The Calvert shocks plates are the same as factory but are thicker and use a bolt for the shock mount no the stud.
Do you have any pics of the ft. mounting hole in the leafs by chance?
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: Thumperdart] #1555806
03/03/14 01:58 AM
03/03/14 01:58 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Mick
No I don't sorry, how soon you doing it? I could get a pic this week.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555807
03/03/14 02:01 PM
03/03/14 02:01 PM
State of confusion
State of confusion
I`m starting on it today if the sliders come in and if not then tomorrow. You said "The front eye is 1/8 in. from the floor" so that tells me you really lowered it since stock from what different guys tell me is 3-3 1/2 inches from floor pan. Sound about right? Thankxxx............
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: Thumperdart] #1555808
03/03/14 02:32 PM
03/03/14 02:32 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yes my car sits low, it was about the lowest the front could go. there was only 1/4 of travel to the bump stop on the front. Its a pain to get rear tires on and off, need to let the suspension drop when jacked up and have to deflate tires and crush them down to get them on and off. It's about 2 inches off the floor to center of bolt if I had to guess.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555809
03/03/14 02:37 PM
03/03/14 02:37 PM
State of confusion
State of confusion
Thankxxxx............if you can confirm that 2"`s that would be great. I`m 3 1/2"`s from floor to center eyelet now which is 3/4`s of an inch lower(towards the ground)than before which might explain my horrible last outing of 6.20 111.17 1.42 60 ft. Mucho appreciated...........I plan on a 1.35 60 9.65 et at around 137 mph which I feel is doable and hopefully within a month...........
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: Thumperdart] #1555810
03/03/14 02:49 PM
03/03/14 02:49 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I will see if my buddy is going to shop and have him measure. I wont be near the shop till end of week.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555811
03/03/14 03:11 PM
03/03/14 03:11 PM
State of confusion
State of confusion
Thankxxxx..............no biggie if not cos I know where I screwed up...........
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555812
03/03/14 03:27 PM
03/03/14 03:27 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I am just looking listening and hopefully learning. I am just wondering if mounting the shock in front of the axle and using compression to control axle rotation and extension to control body seperation would be why they are mounting the shock in front of the axle. The other benifit would be the ability to adjust body seperation and axle rotation with different shock setting versus both being controlled by extension in the shock mounted behind the axle. That's my thoughts, what do you guys think.
Getting old just means you were smarter than some and luckier than others.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: dannysbee] #1555813
03/03/14 04:02 PM
03/03/14 04:02 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
The caltrac controls rotation, you want to be on front because that is the part of the spring that dictates traction. It reacts faster when you are on the front.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555814
03/03/14 04:07 PM
03/03/14 04:07 PM
State of confusion
State of confusion
I`m really thinking about doin this but can a Rancho shock(4 now)handle the hit being in ft?
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: Thumperdart] #1555815
03/03/14 04:18 PM
03/03/14 04:18 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Only one way to know.
I don't know that answer. I would guess yes with a slick tire it could.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555816
03/03/14 04:24 PM
03/03/14 04:24 PM
State of confusion
State of confusion
Never the "smart guy" I always end up doin things two or three times over when I could of done it "right" the first time..........
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: Thumperdart] #1555817
03/03/14 04:26 PM
03/03/14 04:26 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
practice makes perfect!!
Don't think you are doing to bad with your combo.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555818
03/03/14 04:31 PM
03/03/14 04:31 PM
State of confusion
State of confusion
Thankxxx...........But like most of us, we want more but I promise it will go a 9.6 something OR better when I pull my head out and step this pig up.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555819
03/03/14 04:53 PM
03/03/14 04:53 PM
State of confusion
State of confusion
So what do you use as the bolt/shock mount size wise. I would assume the Afcos and other quality shocks use heim joints and my Ranchos run the bushing.........
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555820
03/03/14 05:37 PM
03/03/14 05:37 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
A clearer pic of upper mount
Yes a bolt goes in and has hein end on the shock. I took front rubber bushings out as well and mounted the front shocks solid.
