Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS.................
[Re: 1967dartgt]
#1555803
03/02/14 06:48 PM
03/02/14 06:48 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Are the caltrac mounts similar to the stock ones. Have you managed to maintain your comp damping by pushing the upper mounts up ? Thanks for the pics. ![](/ubbthreads/images/graemlins/thumbs.gif) Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Thumperdart]
#1555808
03/03/14 02:32 PM
03/03/14 02:32 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Yes my car sits low, it was about the lowest the front could go. there was only 1/4 of travel to the bump stop on the front. Its a pain to get rear tires on and off, need to let the suspension drop when jacked up and have to deflate tires and crush them down to get them on and off. It's about 2 inches off the floor to center of bolt if I had to guess.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Thumperdart]
#1555810
03/03/14 02:49 PM
03/03/14 02:49 PM
1967dartgt
Hilltown Pa
I will see if my buddy is going to shop and have him measure. I wont be near the shop till end of week.
[Re: 1967dartgt]
#1555812
03/03/14 03:27 PM
03/03/14 03:27 PM
Posts: 5,160 Texas
dannysbee
Texas
I am just looking listening and hopefully learning. I am just wondering if mounting the shock in front of the axle and using compression to control axle rotation and extension to control body seperation would be why they are mounting the shock in front of the axle. The other benifit would be the ability to adjust body seperation and axle rotation with different shock setting versus both being controlled by extension in the shock mounted behind the axle. That's my thoughts, what do you guys think.
Getting old just means you were smarter than some and luckier than others.
[Re: dannysbee]
#1555813
03/03/14 04:02 PM
03/03/14 04:02 PM
1967dartgt
Hilltown Pa
The caltrac controls rotation, you want to be on front because that is the part of the spring that dictates traction. It reacts faster when you are on the front.
[Re: Thumperdart]
#1555817
03/03/14 04:26 PM
03/03/14 04:26 PM
1967dartgt
Hilltown Pa
practice makes perfect!! Don't think you are doing to bad with your combo. ![](/ubbthreads/images/graemlins/Twocents.gif)
