Re: Pictures of Member's Cars Built for Handling
[Re: MuuMuu101]
#1555524
01/15/14 03:58 AM
01/15/14 03:58 AM
Posts: 780 Woodinville, WA
Viol8r
Woodinville, WA
Trans cooler, oil cooler, brake bias, brake cooling, harness bar, tubular suspension, EFI, adjustable shocks, etc etc etc. We are trying! http://veritasimagerynw.smugmug.com/Cars/Turn-2-Lapping-The-RIdge-4-12/i-SPNdgJR/X2
[Re: Trojmn]
#1555525
01/15/14 12:00 PM
01/15/14 12:00 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
is the pass door misaligned or is the car twisting that much?
love the car BTW...
Misaligned. At the bottom of the list, guess I better do it though Currently has a hilborn intake, 6.1 Hemi, tko600, and ford 9" floater. One more from the Texas Mile:
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Pictures of Member's former Car Built for Handling
[Re: ThermoQuad]
#1555527
01/15/14 03:28 PM
01/15/14 03:28 PM
Posts: 1,443 NW Chicago suburban area
Mopar Mitch
Tom -- Your AAR is missed... I wish you still had it so that we could've possibly run together in the future.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Uhcoog1]
#1555528
01/16/14 01:14 AM
01/16/14 01:14 AM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
Did you have to rework the fender lips to squeeze those tires under there?
[Re: brads70]
#1555529
01/16/14 07:48 AM
01/16/14 07:48 AM
Uhcoog1
Houston Tx
The fender lips were folded up inside (i.e. fender 'rolled'), but that's it for the lips. I do have some other issues, though. I've got 7.2" backspacing front and rear on 18x9.5" tires. With all that backspacing, the tire hits the frame rail about the same time it rubs the fender (1-1.5 turn from center). I try to keep it to 1x turn from center and under when driving- so the turning radius is similar to my truck. I haven't tried an autocross in the car yet, but I've got more than enough for street driving and road course work. No rubbing anywhere with either.
I did have to trim the front and rear corners of the front wheelwell, and I used the adjustable strut rods to locate the tires as well. I was slightly rubbing just off center when turning prior to this fix (back corner of front wheelwell).
I was also rubbing the inner fenders on compression- so I cut out a piece and added contoured trailer fender (!) pieces to gain 1.5" clearance in the compression direction. Ive got ~3" of compression now before bottoming out the LCA (3/16" bump stops in there). Last thing I want is the tire contacting anything at 145+ mph.
[Re: Dan@Hotchkis]
#1555536
06/08/14 07:33 AM
06/08/14 07:33 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
We've got a couple built for fun...
They even literally fly sometimes!
I know you're gonna roll your eyes... but thats by far my favorite pic ov your Challenger. Love the car, but its just too damn low for my tastes. This pic looks "normal" hahahahahaa
