Re: 62 Polara 500 Cruiser
[Re: jcc]
#1554304
12/27/13 07:30 PM
12/27/13 07:30 PM
Posts: 22,717 Bitopia
jcc
Bitopia
39 Replacement rad, moved 2" back, 2" down, and PS cooler attached
[Re: jcc]
#1554306
12/27/13 07:32 PM
12/27/13 07:32 PM
jcc
Bitopia
41 Kevlar Fan shroud, I do not believe in shrouding anymore area then the area directly in front of fan, mainly due to fan aero blockage at higher speeds.
[Re: jcc]
#1554307
12/27/13 07:32 PM
12/27/13 07:32 PM
jcc
Bitopia
42 Outer CF layer, regardless this a plastic semi flexible lightweight fan
[Re: jcc]
#1554308
12/27/13 07:33 PM
12/27/13 07:33 PM
jcc
Bitopia
43 The deepened rad upper support thru holes are for future cold engine air intake feed
[Re: jcc]
#1554311
12/27/13 07:36 PM
12/27/13 07:36 PM
jcc
Bitopia
46 Lightened OEM bumper brackets, w/ alum fasteners
[Re: jcc]
#1554312
12/27/13 07:36 PM
12/27/13 07:36 PM
jcc
Bitopia
47 Having a difficult time designing an efficient/practical "monte carlo" brace
[Re: jcc]
#1554313
12/27/13 07:37 PM
12/27/13 07:37 PM
jcc
Bitopia
48 Tucking bumpers
[Re: jcc]
#1554315
12/27/13 07:39 PM
12/27/13 07:39 PM
jcc
Bitopia
50 So I ground 90% on the external lower welds,the area shown here, before taking it to the chrome shop. However I read online the chrome shops highly suggest customer do not do any grinding since the track record of the customer usually screw up the part. This pic shows what it looked like after chrome shop finished my initial grinding. I'm happy
[Re: jcc]
#1554317
12/27/13 07:41 PM
12/27/13 07:41 PM
jcc
Bitopia
52 The tops of the bumper I avoided grinding, because they are most visible, left it to the experts, this picis 100% their weld prep, for some reason, i asked them not to plate the bumpers until I inspected them. They IMO almost ruined the bumpers or made a huge amount of additional work for me, Now they sit rusting
[Re: jcc]
#1554318
12/27/13 07:42 PM
12/27/13 07:42 PM
jcc
Bitopia
53 90% engine cooling air enters here and above spoiler, any extra down forces can't hurt, right?
[Re: jcc]
#1554320
12/27/13 08:38 PM
12/27/13 08:38 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Would you look at that? Mini-Carbon lay up. Sweet!
[Re: MuuMuu101]
#2730519
01/06/20 12:45 PM
01/06/20 12:45 PM
jcc
Bitopia
55 So I got a project underway that has been on the shelf for almost a decade. I bought a number of 1962 Polara 500 fiberglass hoods from WS Fiberglass when they were still in business. That ordeal is another story. On this street driven cruiser I always wanted a cold air intake, but wanted an efficient stealth look. So attached is my lost foam mockup underneath. A few years back I installed a new alum Rad, lowered it approx 2" and moved it back another 2". This allowed me to deepen the rad bulkhead and add intake air openings, I partitioned the air entering the grill between the radiator and these new openings. For a nearly finished pic of that aspect see pic #43 @ https://board.moparts.org/ubbthread...-62-polara-500-cruiser.html#Post1554276.On the underside of the hood I layered an 1/8" Foam layer first, since this is a Florida car and all my hoods are flat black, to gain a little thermal insulation from the sun, and since grafting onto existing FG can sometimes lead to visible distortion upon final resin cure. I will install rubber flaps on both ends to seal air flow. I'm doing the CF/Kevlar Layup today. I decided not to vac bag as I'm afraid it might distort hood for little gain. I used hand layup with specific areas of added Kelvar. Holes are for aerolatches, and small lift pulls/heat vents.
[Re: jcc]
#2730523
01/06/20 12:53 PM
01/06/20 12:53 PM
jcc
Bitopia
56
So this is almost finished. White interior paint is to radiate less heat. Gold reflective foil is the opposite, the stuff is nearly impossible to get applied smooth. Used a LARGE SS hose clamp to retain neoprene sealing flap on air filter. I will be adding two large hood vents, when finally installed and I can test for the the lowest and/or highest differential air pressure areas on hood for exact vent location.
You can also make out the underside of a small CF aero front trim lip I fabbed up to replace the OEM flat SS trim.
[Re: jcc]
#2731246
01/08/20 08:56 PM
01/08/20 08:56 PM
jcc
Bitopia
#57 White I was doing the hood, I wanted to also improve the air flow post grille and in front of the radiator. I came up with a pair of these custom CF diverters to direct and smooth out the air flow into the radiator, The top is partitioned off by a CF shelf to separate the engine air intake and radiator air flow, They weigh 3? oz'?. They can't be seen behind the screened off grille, so take a good look.
