Page 3 of 5 1 2 3 4 5
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553863
12/27/13 02:54 AM
12/27/13 02:54 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
41
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553864
12/27/13 02:55 AM
12/27/13 02:55 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
42
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553865
12/27/13 02:56 AM
12/27/13 02:56 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
43
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553866
12/27/13 02:57 AM
12/27/13 02:57 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
44 Housing narrowed, with back brace tacked , inspection/filler hole, also note, this detail almost caught me, but if you look closely,
you will see i had to change the angle of the ends of the back brace to miss the shock package i chose, and the shocks
are not large diameter
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553867
12/27/13 02:58 AM
12/27/13 02:58 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
45 Internal oil control plates
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553868
12/27/13 02:59 AM
12/27/13 02:59 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
46 Internal mounting flange gussets
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553869
12/27/13 03:00 AM
12/27/13 03:00 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
47 Custom narrowing jig, with SS 1.5"D x 72" alignment bar and pucks. I made this jig, which does not "walk on water", but since I have maybe 4? rears to narrow, it made sense to me, I would be willing to make it available to other reputable vetted nearby mopar members on a limited term basis, as a favor.
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553870
12/27/13 03:01 AM
12/27/13 03:01 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
48 A doctored/sacrificed 741 center to allow internal access to caps when welding
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553871
12/27/13 03:02 AM
12/27/13 03:02 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
49
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553872
12/27/13 03:03 AM
12/27/13 03:03 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
50 What you do not want to see for alignment, mostly due IMO to back brace welding, GO SLOW, it is difficult to correct
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553873
12/27/13 03:04 AM
12/27/13 03:04 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
51 I always liked the Chaparral 2J "sucker" car, So I wanted as much rear weight rearward, I am abiding by no rules,
I decided to install two oil coolers in the rear trunk area , exhausting thru the rear lip of the fiberglass truck lid,
beneath the rear spoiler. One cooler for motor oil ,other trans, when I go manual in future, the one will be way over kill.
There is a replaceable filter under the housing viewable from rear, seen without curved deflector finished.
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553874
12/27/13 03:05 AM
12/27/13 03:05 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
52 Front view twin coolers
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553875
12/27/13 03:07 AM
12/27/13 03:07 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
53 Fuel cell, fuel pump. filter and plumbing installed
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553876
12/27/13 03:08 AM
12/27/13 03:08 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
54 Remote PH-6 Filter and pre screen , mounted thru trunk floor for easy changing, battery, and shut off switch.
Plan is for additional with external shutoff switch for track safety
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553877
12/27/13 03:09 AM
12/27/13 03:09 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
55
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553878
12/27/13 03:10 AM
12/27/13 03:10 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
56 Drivers side Diff pump cooler and filter
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553879
12/27/13 03:11 AM
12/27/13 03:11 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
57 Interior plumbing of accumulator, one way valve, solenoid, and fire system, and diff cooler lines and temp gauge, Remember, no rules
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553880
12/27/13 03:12 AM
12/27/13 03:12 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
58 Thru the firewall engine oil feed, will have secondary hot oil rupture cover added full length
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553881
12/27/13 03:13 AM
12/27/13 03:13 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
59 Rear Axle installed, with MW 45mm axles and large ford sealed bearings shocks inverted, composite springs, Alum MP 8.75, sure grip, billet caps, 3.55, MW glued alum 1350 DS, directed oil cooler
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553882
12/27/13 03:14 AM
12/27/13 03:14 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
60 Assembled, without left trunk extension. The diff cooler will be horizontal in the rear most part center inside the trunk,
exhausting thru the truck floor, just above the u bar protecting the fuel cell, v likely a low pressure aero area, caused by the fuel cell,
305/17's
