Re: 72 Swinger Track day/ProTour practice car
[Re: jcc]
#1553843
12/27/13 01:26 AM
12/27/13 01:26 AM
Posts: 23,607 Here
jcc
No soup for you!!!
No soup for you!!!
Here
21 front added fuel cell cross member, additional gusset added to upper shock mounting point
I'm with Helmuth Hübener, and no soup is being served today.
[Re: jcc]
#1553844
12/27/13 01:26 AM
12/27/13 01:26 AM
Posts: 23,607 Here
jcc
No soup for you!!!
No soup for you!!!
Here
22 Looking rearward with cross members in place, pass side trunk floor yet to be fitted
[Re: jcc]
#1553845
12/27/13 01:28 AM
12/27/13 01:28 AM
Posts: 23,607 Here
jcc
No soup for you!!!
No soup for you!!!
Here
23 Underside rear Bat box and unfinished rear Pass side fuel cell mount
[Re: jcc]
#1553846
12/27/13 01:29 AM
12/27/13 01:29 AM
Posts: 23,607 Here
jcc
No soup for you!!!
No soup for you!!!
Here
24 Locating cage main hoop floor mounts and installing frame connectors, thru the floor, 2x3x .083
[Re: jcc]
#1553847
12/27/13 01:30 AM
12/27/13 01:30 AM
Posts: 23,607 Here
jcc
No soup for you!!!
No soup for you!!!
Here
25 I like my seating position way back, there will not be a rear seat, and best location for roll bar seemed to be as pictured.
[Re: jcc]
#1553848
12/27/13 01:31 AM
12/27/13 01:31 AM
Posts: 23,607 Here
jcc
No soup for you!!!
No soup for you!!!
Here
26 Front floor was getting a little thin, so we expected to patch, and while in the area, i added the welded an oval tube thru the OEM TB cross member for the SS fuel supply and return lines, to facilitate routing, and be away from the ground. I also welded up any internal OEM gussets i could reach
[Re: jcc]
#1553849
12/27/13 01:32 AM
12/27/13 01:32 AM
Posts: 23,607 Here
jcc
No soup for you!!!
No soup for you!!!
Here
27 I added a holed gusset to support cage down bar base plate, and welded my 1/8" base plate to that
[Re: jcc]
#1553850
12/27/13 01:33 AM
12/27/13 01:33 AM
Posts: 23,607 Here
jcc
No soup for you!!!
No soup for you!!!
Here
28 RF Floor replace, pseudo mini torque box and roll bar down bar mounting plate
[Re: jcc]
#1553851
12/27/13 01:34 AM
12/27/13 01:34 AM
Posts: 23,607 Here
jcc
No soup for you!!!
No soup for you!!!
Here
29 Floor install with weld lugs
[Re: jcc]
#1553852
12/27/13 01:34 AM
12/27/13 01:34 AM
Posts: 23,607 Here
jcc
No soup for you!!!
No soup for you!!!
Here
30 Dr Side Plate, I removed floor to able to weld directly to OEM under frame and added holed gusset
[Re: jcc]
#1553853
12/27/13 01:35 AM
12/27/13 01:35 AM
Posts: 23,607 Here
jcc
No soup for you!!!
No soup for you!!!
Here
31 Cage base plate in place and extra internal OEM frame gusset added inside OEM frame
[Re: jcc]
#1553854
12/27/13 01:36 AM
12/27/13 01:36 AM
Posts: 23,607 Here
jcc
No soup for you!!!
No soup for you!!!
Here
32 Mini torque box/front down roll bar brace frame gusset
[Re: jcc]
#1553856
12/27/13 01:41 AM
12/27/13 01:41 AM
Posts: 23,607 Here
jcc
No soup for you!!!
No soup for you!!!
Here
34 Inner wheelhouse mini tub extension
[Re: jcc]
#1553858
12/27/13 01:46 AM
12/27/13 01:46 AM
Posts: 23,607 Here
jcc
No soup for you!!!
No soup for you!!!
Here
36 Mini tub welding complete
[Re: jcc]
#1553859
12/27/13 01:50 AM
12/27/13 01:50 AM
Posts: 23,607 Here
jcc
No soup for you!!!
No soup for you!!!
Here
37 Minoi tub inner fender filler panel install
[Re: jcc]
#1553860
12/27/13 01:51 AM
12/27/13 01:51 AM
Posts: 23,607 Here
jcc
No soup for you!!!
No soup for you!!!
Here
38 Frame cut, contrary to others I feel little strength is added to the 1/8" steel replacement mounting box by using the OEM 18g?? steel outer flange, additionally, it makes for a tougher weld design. so I completely removed it.
[Re: jcc]
#1553861
12/27/13 01:52 AM
12/27/13 01:52 AM
Posts: 23,607 Here
jcc
No soup for you!!!
No soup for you!!!
Here
39 Frame cut, contrary to others I feel little strength is added to the 1/8" steel replacement mounting box by using the OEM 18g?? steel outer flange, additionally, it makes for a tougher weld design. so I completely removed it
