Re: 72 Swinger Track day/ProTour practice car
[Re: jcc]
#1553843
12/27/13 02:26 AM
12/27/13 02:26 AM
Posts: 22,697 Bitopia
jcc
Bitopia
21 front added fuel cell cross member, additional gusset added to upper shock mounting point
[Re: jcc]
#1553844
12/27/13 02:26 AM
12/27/13 02:26 AM
jcc
Bitopia
22 Looking rearward with cross members in place, pass side trunk floor yet to be fitted
[Re: jcc]
#1553846
12/27/13 02:29 AM
12/27/13 02:29 AM
jcc
Bitopia
24 Locating cage main hoop floor mounts and installing frame connectors, thru the floor, 2x3x .083
[Re: jcc]
#1553847
12/27/13 02:30 AM
12/27/13 02:30 AM
jcc
Bitopia
25 I like my seating position way back, there will not be a rear seat, and best location for roll bar seemed to be as pictured.
[Re: jcc]
#1553848
12/27/13 02:31 AM
12/27/13 02:31 AM
jcc
Bitopia
26 Front floor was getting a little thin, so we expected to patch, and while in the area, i added the welded an oval tube thru the OEM TB cross member for the SS fuel supply and return lines, to facilitate routing, and be away from the ground. I also welded up any internal OEM gussets i could reach
[Re: jcc]
#1553849
12/27/13 02:32 AM
12/27/13 02:32 AM
jcc
Bitopia
27 I added a holed gusset to support cage down bar base plate, and welded my 1/8" base plate to that
[Re: jcc]
#1553852
12/27/13 02:34 AM
12/27/13 02:34 AM
jcc
Bitopia
30 Dr Side Plate, I removed floor to able to weld directly to OEM under frame and added holed gusset
[Re: jcc]
#1553853
12/27/13 02:35 AM
12/27/13 02:35 AM
jcc
Bitopia
31 Cage base plate in place and extra internal OEM frame gusset added inside OEM frame
[Re: jcc]
#1553855
12/27/13 02:39 AM
12/27/13 02:39 AM
jcc
Bitopia
33
[Re: jcc]
#1553856
12/27/13 02:41 AM
12/27/13 02:41 AM
jcc
Bitopia
34
[Re: jcc]
#1553857
12/27/13 02:42 AM
12/27/13 02:42 AM
jcc
Bitopia
35
[Re: jcc]
#1553858
12/27/13 02:46 AM
12/27/13 02:46 AM
jcc
Bitopia
36
[Re: jcc]
#1553860
12/27/13 02:51 AM
12/27/13 02:51 AM
jcc
Bitopia
38 Frame cut, contrary to others I feel little strength is added to the 1/8" steel replacement mounting box by using the OEM 18g?? steel outer flange, additionally, it makes for a tougher weld design. so I completely removed it.
[Re: jcc]
#1553861
12/27/13 02:52 AM
12/27/13 02:52 AM
jcc
Bitopia
39 Frame cut, contrary to others I feel little strength is added to the 1/8" steel replacement mounting box by using the OEM 18g?? steel outer flange, additionally, it makes for a tougher weld design. so I completely removed it
