Page 3 of 5 1 2 3 4 5
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553863
12/27/13 01:54 AM
12/27/13 01:54 AM
Capital of Narcissism
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
41 Driveshaft Safety hoop
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553864
12/27/13 01:55 AM
12/27/13 01:55 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
42 Main Hoop roll bar mockup 4130
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553865
12/27/13 01:56 AM
12/27/13 01:56 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
43 8.75" Back brace lightened
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553866
12/27/13 01:57 AM
12/27/13 01:57 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
44 Housing narrowed, with back brace tacked , inspection/filler hole, also note, this detail almost caught me, but if you look closely,
you will see i had to change the angle of the ends of the back brace to miss the shock package i chose, and the shocks
are not large diameter
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553867
12/27/13 01:58 AM
12/27/13 01:58 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
45 Internal oil control plates
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553868
12/27/13 01:59 AM
12/27/13 01:59 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
46 Internal mounting flange gussets
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553869
12/27/13 02:00 AM
12/27/13 02:00 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
47 Custom narrowing jig, with SS 1.5"D x 72" alignment bar and pucks. I made this jig, which does not "walk on water", but since I have maybe 4? rears to narrow, it made sense to me, I would be willing to make it available to other reputable vetted nearby mopar members on a limited term basis, as a favor.
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553870
12/27/13 02:01 AM
12/27/13 02:01 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
48 A doctored/sacrificed 741 center to allow internal access to caps when welding
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553871
12/27/13 02:02 AM
12/27/13 02:02 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
49 Rear housing /Flange pre weld match up
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553872
12/27/13 02:03 AM
12/27/13 02:03 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
50 What you do not want to see for alignment, mostly due IMO to back brace welding, GO SLOW, it is difficult to correct
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553873
12/27/13 02:04 AM
12/27/13 02:04 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
51 I always liked the Chaparral 2J "sucker" car, So I wanted as much rear weight rearward, I am abiding by no rules,
I decided to install two oil coolers in the rear trunk area , exhausting thru the rear lip of the fiberglass truck lid,
beneath the rear spoiler. One cooler for motor oil ,other trans, when I go manual in future, the one will be way over kill.
There is a replaceable air intake filter that slides under the housing and that opening is viewable here from the rear, seen without curved deflector finished.
I was concerned about sucking into the trunk area all the kicked-up road dust/debris.
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553874
12/27/13 02:05 AM
12/27/13 02:05 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
52 Front view twin trunk oil coolers
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553875
12/27/13 02:07 AM
12/27/13 02:07 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
53 Fuel cell, fuel pump. filter and plumbing installed
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553876
12/27/13 02:08 AM
12/27/13 02:08 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
54 Remote PH-6 Filter and pre screen , mounted thru trunk floor for easy changing, battery, and shut off switch.
Plan is for additional with external shutoff switch for track safety
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553877
12/27/13 02:09 AM
12/27/13 02:09 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
55
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553878
12/27/13 02:10 AM
12/27/13 02:10 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
56 Drivers side Diff pump cooler and filter
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553879
12/27/13 02:11 AM
12/27/13 02:11 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
57 Interior plumbing of accumulator, one way valve, solenoid, and fire system, and diff cooler lines and temp gauge, Remember, no rules
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553880
12/27/13 02:12 AM
12/27/13 02:12 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
58 Thru the firewall engine oil feed, will have secondary hot oil rupture cover added full length
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553881
12/27/13 02:13 AM
12/27/13 02:13 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
59 Rear Axle installed, with MW 45mm axles and large ford sealed bearings shocks inverted, composite springs, Alum MP 8.75, sure grip, billet caps, 3.55, MW glued alum 1350 DS, directed oil cooler
Re: 72 Swinger Track day/ProTour practice car [Re: jcc] #1553882
12/27/13 02:14 AM
12/27/13 02:14 AM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
60 Assembled, without left trunk extension. The diff cooler will be horizontal in the rear most part center inside the trunk,
exhausting thru the truck floor, just above the u bar protecting the fuel cell, v likely a low pressure aero area, caused by the fuel cell,
305/17's
