72 Swinger Track day/ProTour practice car
#1553823
12/27/13 01:06 AM
12/27/13 01:06 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
1972 Dart Swinger Project
I have a number of more personally important car projects that I have in the dream pipeline. However I felt as much confidence as I have in my own abilities, I suspected a budget "practice" project first might be useful to work thru some of the skills, lessons, etc needed. This bought on ebay, sight unseen nearby plain jane, dime a dozen, 1972 Swinger fit that bill nicely. A Pro tour/track day car was the goal ( i really dislike the "pro tour" moniker, seems its more for show then go, IMO). Any and all questions and criticism are welcomed, but with some basis, and that helps everybody. Pic #1 I picked up the car, pictured in Orlando, and at the first gas stop, I had to remove the hideous rear pedestal trunk mounted wing.
I'm with Helmuth Hübener, and no soup is being served today.
Re: 72 Swinger Track day/ProTour practice car
[Re: jcc]
#1553824
12/27/13 01:08 AM
12/27/13 01:08 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
2 Car had rust, but was complete, and was pushed in just behind drivers door from a previous accident
[Re: jcc]
#1553825
12/27/13 01:09 AM
12/27/13 01:09 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
3 Smushed in quarter
[Re: jcc]
#1553826
12/27/13 01:11 AM
12/27/13 01:11 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
4 After frame shop
[Re: jcc]
#1553827
12/27/13 01:12 AM
12/27/13 01:12 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
5 We quickly dropped in a 360 with headers however it had a 7.25 rear end, it was only going to be a short lived joy ride
[Re: jcc]
#1553828
12/27/13 01:13 AM
12/27/13 01:13 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
6 The 1972 360 was built by Dan "No Dyno" Davorak, with Hughes ported iron heads, SS 2.02's, Crower Hyd Cam, Lunati chromed cast crank, internally balanced, Fluidamper, 9:1 Cast pistons, a real mild build for street. Dual MP intake 650 VS, valley tray, windage tray, The already built SB 413 EFI Tunnel ram roller E head ported rocket motor comes later.
[Re: jcc]
#1553829
12/27/13 01:14 AM
12/27/13 01:14 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
7 The 904 was rebuilt with some upgrades, added a deep pan, and got a little carried away with milling away excess weight from filter extension.
[Re: jcc]
#1553830
12/27/13 01:15 AM
12/27/13 01:15 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
8 The Front spindles where polished. shot peened, cryo treated and yellow zinc plated.
[Re: jcc]
#1553831
12/27/13 01:15 AM
12/27/13 01:15 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
9 The Wilwood 11.5" front brakes installed, with Alum Hubs and long wheel studs, brakes were grossly undersized by my error, will be upgraded soon to 13" rotors sitting on shelf, aligned with max caster and negative camber, front tire is 265/17
[Re: jcc]
#1553832
12/27/13 01:16 AM
12/27/13 01:16 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
10 Front frame needed slight clearancing for new UCA
[Re: jcc]
#1553833
12/27/13 01:17 AM
12/27/13 01:17 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
11 I believe these are firm feel, very nice
[Re: jcc]
#1553834
12/27/13 01:19 AM
12/27/13 01:19 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
12 LCA with stiffening plates, and most here likely know how little regard I have for this "following the herd" mod. Never again. I did add a reinforcing washer to sway bar tab
[Re: jcc]
#1553835
12/27/13 01:19 AM
12/27/13 01:19 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
13 The firm Feel grease lower pivots, nice, used Urethane bushings everywhere, added alum brake struts
[Re: jcc]
#1553836
12/27/13 01:20 AM
12/27/13 01:20 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
14 I cutout the rear trunk for new fuel cell and other mods
[Re: jcc]
#1553837
12/27/13 01:21 AM
12/27/13 01:21 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
15 SS battery tray, sunk into floor
[Re: jcc]
#1553838
12/27/13 01:22 AM
12/27/13 01:22 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
16 Right side inner rear frame gusset, for new fuel cell cross member, reinforce relocated rear spring shackle, and reinforce rear cage down bar. Plug welds hidden by added cross member
[Re: jcc]
#1553839
12/27/13 01:23 AM
12/27/13 01:23 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
17 Drivers side
[Re: jcc]
#1553840
12/27/13 01:24 AM
12/27/13 01:24 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
18 SS Fuel cell container, to be located front to re, with protective white wrap
[Re: jcc]
#1553841
12/27/13 01:24 AM
12/27/13 01:24 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
19 Rear OEM cross member gets lighter
[Re: jcc]
#1553842
12/27/13 01:25 AM
12/27/13 01:25 AM
Posts: 23,593 Here
jcc
No soup for you!!!
No soup for you!!!
Here
20 To be added fuel cell rear cross member, with protector bar
