Page 3 of 3 1 2 3
Re: Hard-to-detect flat-tappet cam failure [Re: pittsburghracer] #1552561
12/26/13 05:45 PM
12/26/13 05:45 PM
IL
furious70 Offline
furious70  Offline
IL
in the video you see the one lifter was marked '15' on it before he put it in the box. Must be done before they put them in the break in mule.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Hard-to-detect flat-tappet cam failure [Re: furious70] #1552562
12/26/13 08:55 PM
12/26/13 08:55 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The break in mule lifter bore geometry will surely be different then the engines lifter bore geometry. So I really dont see the benifit in this pre breakin machine. Maybe it would help a little though.
Better off imo to start with said engine and lighter springs, goood lube and make sure all the lifters are not to tight and rotate in thier bores.
Page 3 of 3 1 2 3
