Hard-to-detect flat-tappet cam failure
#1552521
12/24/13 04:31 PM
12/24/13 04:31 PM
Posts: 223 California
70Drop
California
I thought I would share a cautionary tale of woe. I decided to go flat-tappet on the 500" stroker in my Duster. It was kind of a big cam for a flat-tappet (256 @ 0.050, .575 lift), not that I'm blaming that for the failure. For the purposes of this post, let's assume I did everything right for break-in and maintenance (which I'm pretty sure I did). I adjusted the valves at about 5 hours of operating time and decided to pull the lifters at the same time (through the drain-back openings in the heads), just to get an idea of how the cam was faring. All the lifters looked perfect, and the valve adjustment did not change at all from the first adjustment after break-in. I noticed some fine metal particles suspended in the oil when I changed it, but I didn't think much of it, since the engine was still pretty new. Fast-forward to a few weeks ago when I decided to put in a new oil pan. Since I was down there, I decided to pull some bearing caps and see how things were wearing. What I found was a lot more wear on the bearings than I would expect on a new engine. So I pulled the intake and found the tips of three cam lobes in the early stages of failure (missing metal, pitting). But to my surprise the lifters were still PERFECT (Isky "cool face" lifters). Long story short, the engine is now ready to go back in with a roller cam ![](/ubbthreads/images/graemlins/boogie.gif) I could speculate that those cam lobes could have kept going flat, and the valve adjustments wouldn't have varied at all, since the lifters weren't going bad. Of course, I wouldn't use valve adjustment variation alone to detect a cam issue. But this experience taught me that consistent valve lash does not mean the cam is good!
Re: Hard-to-detect flat-tappet cam failure
[Re: dodger mope]
#1552524
12/24/13 04:44 PM
12/24/13 04:44 PM
70Drop
California
stories like that gives a person nightmares! what camshaft company?
Engle
[Re: 70Drop]
#1552525
12/24/13 04:48 PM
12/24/13 04:48 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Actually, not a big flat tappet, my brother just completed Drag Week with a 272 @ .50 .640 lift cam with cool face lifters. If you look for it, you will find something I guess, I would have drove it until it started popping back through the carb, and then said, "Huh, maybe I should take a valve cover off and check the lash!"
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: dodger mope]
#1552526
12/24/13 11:09 PM
12/24/13 11:09 PM
Posts: 429 Washington
skrews
Washington
X 2 on what cam company ![](/ubbthreads/images/graemlins/popcrn.gif)
[Re: skrews]
#1552527
12/24/13 11:58 PM
12/24/13 11:58 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
You sounds either extremely paranoid or you suspect you did something wrong on start-up. Lets hear the whole story. No valve lash change, zero issues and you still go to the trouble of pulling the lifters in the car on an assembled engine. Something just sounds fishy. I know for a fact Brad Penn and a zinc additive appear to have metal suspended and will even leave a fine black residue in the bottom of the oil pan.
[Re: pittsburghracer]
#1552529
12/25/13 12:15 AM
12/25/13 12:15 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
It's your story so you can tell it any way you want. Rockers not out of adjustment? and the lobes are worn? No ware on the lifters? Yes with those key elements ,I guess it would be hard to detect cam failure. Yes, by all means trash the cam manufacture . Make sure when you install the roller lifters you put the rollers on the cam, they will last longer. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: rowin4]
#1552530
12/25/13 12:33 AM
12/25/13 12:33 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Did you have the cam nitrided ? I run a flat tappet thats 264 and 270 @ .050 with .585 and .592 lift. I use 1.6 rockers so my lift is about .630. I put the eng in the car in June 2011 and its been great. Driven many miles and raced a few times with no signs of any failure. I bought my cam from Dwayne Porter who had it nitrided as per his recomendation which hardens the cam metal. I also use the lifters with the oil hole in the bottom. I use Valvoline VR1 racing oil and always put a can of the zinc additive in at every oil change. But I have had no problems at all and am 100% pleased with mine. Sorry to hear of your problems and hope you get it ironed out. If you would go back to or ever use a solid flat tappet again I would call Dwayne Porter and talk with him as he knows what he is talking about. He talked me out of the roller I was going to use in my street eng as we talked about the spring pressure and roller lifter failures that can also happen and I ended up going with the solid flat tappet and dont regret it one bit. Ron
[Re: 70Drop]
#1552531
12/25/13 02:29 AM
12/25/13 02:29 AM
BradH
Engle
What open and closed spring pressures, and who spec'd the springs?
[Re: Crizila]
#1552533
12/25/13 03:46 AM
12/25/13 03:46 AM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Just spitballing… Double springs? If so, were the inners pulled on break-in?
I have seen the timing mark jumping around when a lobe(s) started to go.
[Re: 70Drop]
#1552535
12/25/13 05:07 AM
12/25/13 05:07 AM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
Could you post some pics? If the top of the cam is showing signs of trouble it would be soon you'd have big problems. The brand is not too important as there are only a few core companies and the P55 cores for the Mopar are long gone(unless someone knows where some are stashed???).
[Re: goldmember]
#1552536
12/25/13 05:34 AM
12/25/13 05:34 AM
70Drop
California
OK. I was trying not to have this thread be about my cam break-in, but inquiring minds want to know . . .
Broken in on outer springs of a dual-spring setup (350 lb. open pressure when paired). Twenty minutes varying between 1800 and 2200 rpm on start-up. VR1 racing oil and GM EOS at break-in, changed shortly after break-in, and new VR1/filter installed. I cut up the first filter, and it was clean. Suspended flecks of metal in the break-in oil (only visible in light), which is normal ring-to-bore seating debris.
I'm not trying to blame Engle for anything. I've used three of their cams in the past, and they've always been good. Cam was not nitrided.
I've built eight flat-tappet engines, and this is the first one I've had problems with. I've seen it happen to someone else's engine, though. It's not unheard of.
The engine is back together with a Comp roller. I was actually planning to go roller, anyhow. Should be running by Friday.
Just passing on my experience, as it was interesting how it failed - damage to the cam and nothing on the lifters. I just figured the lifters would be the first thing to fail.
And yes, I do check things carefully. I'm a certified aircraft mechanic. I'm sure glad I found this problem when I did, before it took the whole engine out.
I've got nothing against flat-tappets - I've run them most of my life!
[Re: 70Drop]
#1552539
12/25/13 06:45 AM
12/25/13 06:45 AM
goldmember
Gainesville,FL
Oh, and it's not much trouble to check lifters on an assembled engine(big-block). I've done it several times before. When the valve covers are off for a valve adjustment, just pull out each pushrod and use a magnet-on-a-stick to pull each lifter through the drain-back holes in the heads. Not much more trouble than adjusting the valves. It probably adds 1/2 hour to the job. Of course I don't do this all the time, but after the first 5 hours on a new engine, I figured it was good insurance. As it turned out, it didn't do me any good at all!
It did a bunch of good as the results of a true flat lobe are far worse. Most flat lobes are that,flat and plenty of cleanup. LOL You caught it early wtf are u bitchin about?? Merry Xmas!
[Re: 70Drop]
#1552540
12/25/13 06:49 AM
12/25/13 06:49 AM
MoparBilly
Phoenix, AZ
Wow, much uglier than I was expecting to see.
