Re: My Gen III Hemi A-body build.
[Re: RylisPro]
#1552427
03/08/15 12:48 AM
03/08/15 12:48 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
As I get my firewall to A pillar bars done I can start wiring for real, got the passenger side done today will get the other one soon. Those bars are going to dictate my fuse box mounting,ecm mounting and voltage regulator, Bat + junction and buss bar placement. Going to have through firewall battery 3/8" studs for pos and neg both behind the cylinder heads as hidden as possible. Been thinking I might mount an encased 200 amp fuse inline with the charge wire to. Firewall is almost done with filler and smoothing, still need to cut out master cylinder plate and weld in a new one out of 1/8" and plate in the down bars to the shock mounts a little then the engine compartment will be in paint soon after.
Mopar to the bone!!!
[Re: 72Swinger]
#1552431
03/08/15 01:34 PM
03/08/15 01:34 PM
Posts: 2,432 NorCal
RylisPro
NorCal
yes, his theory is any grounds to frame amplify electrical noise exponentially.
Ok, just remembered that I actually did a similar setup for the positive cable using this red covered terminal block JB4-375-RC. http://www.texasindustrialelectric.com/_junction_blocks.asp For my negative I ran a fat 00 cable from the engine block to the battery negative but ran other grounds to the frame.
I will get this black terminal block instead
[Re: RylisPro]
#1552432
03/31/15 06:21 AM
03/31/15 06:21 AM
72Swinger
Nebraska
So I was putting my sweet newly covered dash pad in the shed and saw that my driver side fender had slid from its perch on top of a bunch of other junk and hit a dolley and my lawn mower on the way down to landing face down on the concrete. Not a morale boost this guy. Its gonna need paint to fix, AAAAAAAARRRRRRR!!!
[Re: 72Swinger]
#1806548
04/18/15 11:16 PM
04/18/15 11:16 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
This looks amazing Emil! Great job
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: 72Swinger]
#1806592
04/19/15 12:07 AM
04/19/15 12:07 AM
72Swinger
Nebraska
Thanks guys, I have a ton of stuff left to iron out but man does it feel good to get going. Im not gonna predict any "it will run by 0000 day" crap to add pressure either lol!
[Re: 72Swinger]
#1806595
04/19/15 12:10 AM
04/19/15 12:10 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks guys, I have a ton of stuff left to iron out but man does it feel good to get going. Im not gonna predict any "it will run by 0000 day" crap to add pressure either lol! I'm at a stagnant point with mine where I feel like I'm just pecking away at the same thing over and over. Hoping to get the engine bay relatively wrapped up here soon and stab my mock up engine in there!
[Re: 72Swinger]
#1806661
04/19/15 01:54 AM
04/19/15 01:54 AM
72Swinger
Nebraska
Definitely mock up BEFORE engine bay is painted. I have kept my engine bay scratch free so far because of that. BUT even though the clutch master has a plastic cap over the outlet fitting DOES NOT mean it wont still freaking DRIP! If anyone sees the mark that made, ill kick them in the nads....
[Re: 72Swinger]
#1806873
04/19/15 01:39 PM
04/19/15 01:39 PM
72Swinger
Nebraska
They are needed with high offset wheels and 10-12 wide tires IMO. I plan to eventually run a 295 on the front some day. Just something I did since I was already taking the engine compartment down anyway.
[Re: 72Swinger]
#1807336
04/19/15 11:31 PM
04/19/15 11:31 PM
Posts: 751 Saint Peters, MO
Brian
Saint Peters, MO
That looks sweet! I hope mine will look that good in few more months.
1971 6.1 Gen III Hemi Duster
