Page 5 of 6 1 2 3 4 5 6
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552128
07/07/14 11:20 AM
07/07/14 11:20 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
OK...... Project Hemi.... Got more done this weekend.. Change out the oil with VR1 40, lowered the car and adjusted the torsion bars, finished the ignition wiring, put the NASCAR rims back on and odds and ends. It is getting closer...
Back on the ground..
Troy
Houston Mopar Connection Club
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552129
07/07/14 11:22 AM
07/07/14 11:22 AM
Houston, Tx
Houston, Tx
Engine bay closer to completion with hoses and gaskets here and there along with changing out the oil.
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552130
07/07/14 11:29 AM
07/07/14 11:29 AM
Houston, Tx
Houston, Tx
Hemi badge with "hint" of 426 Hemi from chrome dome.
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552131
07/07/14 11:29 AM
07/07/14 11:29 AM
Houston, Tx
Houston, Tx
straight on,
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552132
07/07/14 11:54 AM
07/07/14 11:54 AM
Houston, Tx
Houston, Tx
Looking down..
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552133
07/07/14 11:58 AM
07/07/14 11:58 AM
Houston, Tx
Houston, Tx
passenger side
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552134
07/07/14 11:59 AM
07/07/14 11:59 AM
Houston, Tx
Houston, Tx
driver's
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552135
07/13/14 12:08 AM
07/13/14 12:08 AM
Houston, Tx
Houston, Tx
Well,
She lives !!! Man, I'm beat.............
First thing this morning I discovered no fuel was getting to the carbs, turned out to be a faulty fuel pump (damn expensive new Carter). I took out the fuel pump AND rod from the 440 that had been working perfectly. That did the ticket.........
I positioned the distributor where I thought it should be and low-and-behold, she fired up and ran before the first revolution of the started was completed !!! It was a very happy feeling..... Seems though I might have a small situation. There appeared a small leak of coolant coming out of the passenger side head gasket seam in the rear. After starting the motor a couple of times and running it, it has totally gone away.... I'll inspect it in the morning..... The motor has sat a couple of years since it's initial start-up by the builder....... I may remove the valve cover and retorque the head bolts........ We'll see...... All in all, she rans great..... Now I need to fine tune it and get the best I can out of idle....... The rear carb is a bad to adjust due to the angle of the fuel/air mixture screws and the front carb.....
Here's a video of Jacob cranking it up...... Sorry for the video quality..
The Elephant cranking up via Jacob
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552136
07/13/14 07:20 PM
07/13/14 07:20 PM
central il.
second 70 Offline
second 70  Offline
central il.
Troy Glad to see you got your hemi up and running. I have seen hemi's leak antifreeze at bottom of the heads due to the intake bolts being over tightened and have it stop just by backing off the intake bolts a quarter turn. But then it might start to leak oil out of back of manifold and you'll have to remove and reinstall the intake. Good-Luck Mike
Re: Hemi Transplant in my '69 Daytona [Re: second 70] #1552137
07/13/14 09:31 PM
07/13/14 09:31 PM
Houston, Tx
Houston, Tx
I drove the car again today around the block and have fired it up numerous times yesterday and today... Nada on the leak......... dry as a bone everywhere.....
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552138
07/13/14 09:56 PM
07/13/14 09:56 PM
central il.
second 70 Offline
second 70  Offline
central il.
Glad to hear that!
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552139
07/13/14 10:34 PM
07/13/14 10:34 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Excellent, the swap really looks good.
Sheldon
Re: Hemi Transplant in my '69 Daytona [Re: second 70] #1552140
07/17/14 04:52 PM
07/17/14 04:52 PM
California
mickm Offline
mickm  Offline
California
still waiting for driving and performance reports!
Re: Hemi Transplant in my '69 Daytona [Re: mickm] #1552141
07/18/14 02:37 AM
07/18/14 02:37 AM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
great job...looks awesome...quick question did you have to modify the shift linkage shaft per tti instructions or use that bracket that came in the kit...im doing same build as we speak...any advice would be appreciated?also how close did your.96 torsion bars come to on you your passenger or drivers header?ty in advance..mike
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: Hemi Transplant in my '69 Daytona [Re: sublimehemi] #1552142
07/18/14 10:37 AM
07/18/14 10:37 AM
Houston, Tx
Houston, Tx
Once I get the newly developed brake problem squared away, I will for sure get her out. I have to fine tune the motor though ( install light springs in the distributor )
Mike,
Thus far, I have no difficulties with the shifter. I had to put the shifter lock-block upside-down like they mention, but that was about it. I SLIGHTLY bent the arm down a wee bit so the pin of the block didn't rub the floor pan. I can try and take a picture of the set-up when I get back home. But, long story short, I didn't have to cut and reweld the support arm. I have no issues with the torsion bar.
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552143
08/04/14 11:56 AM
08/04/14 11:56 AM
Houston, Tx
Houston, Tx
Well, she is getting quite close to completion.. I need to tidy up a few things. Due to a change in weekend plans, I decided to haul the Daytona down to my favorite exhaust shop to have the QTP dumps welded in and exhaust buttoned up. Came out pretty nice. The car sounds SO different without open headers......... I almost didn't hear it, relatively speaking of course to what I heard before with open headers.
1. heading out to the shop ( too far to drive with open headers and what would be its maiden voyage )
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552144
08/04/14 11:56 AM
08/04/14 11:56 AM
Houston, Tx
Houston, Tx
2. Just pulled her off the trailer
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552145
08/04/14 11:57 AM
08/04/14 11:57 AM
Houston, Tx
Houston, Tx
3. Waiting in line..... Needless to say, she attracted some attention
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552146
08/04/14 11:57 AM
08/04/14 11:57 AM
Houston, Tx
Houston, Tx
4. Her turn, heading up on the rack
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552147
08/04/14 11:58 AM
08/04/14 11:58 AM
Houston, Tx
Houston, Tx
1. Tech welding things up
Troy
