Page 2 of 6 1 2 3 4 5 6
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552068
04/02/14 08:42 PM
04/02/14 08:42 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
last one of headers.
Troy
Houston Mopar Connection Club
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552069
04/02/14 08:43 PM
04/02/14 08:43 PM
Houston, Tx
Houston, Tx
Dipstick modification..
I used a piece of wire to make a template of sorts to I could pattern the bends/modifications to the OEM dipstick tube to accommodate the headers. I think it came out pretty good... Not touching the header tubes and the dipstick can be inserted just fine..........
Alright guys,,,,,, You know what I mean...
1. wire used for template
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552070
04/02/14 08:43 PM
04/02/14 08:43 PM
Houston, Tx
Houston, Tx
routed around header tube
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552071
04/02/14 08:44 PM
04/02/14 08:44 PM
Houston, Tx
Houston, Tx
template next to OEM reproduction from MegaPartsUSA
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552072
04/02/14 08:45 PM
04/02/14 08:45 PM
Houston, Tx
Houston, Tx
In position..
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552073
04/02/14 08:45 PM
04/02/14 08:45 PM
Houston, Tx
Houston, Tx
Another..
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552074
04/02/14 08:47 PM
04/02/14 08:47 PM
Houston, Tx
Houston, Tx
I have since, after this picture was taken, adjusted it some more so it is more vertical for battery tray clearance... It was brought to my attention on the proximity of the handle to the battery tray..
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552075
04/04/14 01:47 PM
04/04/14 01:47 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
looking good troy. slowly, but slowly......
Re: Hemi Transplant in my '69 Daytona [Re: Golden-Arm] #1552076
04/06/14 06:03 PM
04/06/14 06:03 PM
new jersey
Black 69 Beeper Offline
new jersey
i want to transplant one of those into my road runner too someday. awesome motor!
Re: Hemi Transplant in my '69 Daytona [Re: Black 69 Beeper] #1552077
04/28/14 10:51 AM
04/28/14 10:51 AM
Houston, Tx
Houston, Tx
Saturday:
rearranged the garage exchanging parking of my friend's Superbee and my Daytona. Here's where I start today. Front suspension is pretty much out if the way. I will remove the lower control arms and torsion bars, exhaust, then position the dolly under the kmember and tranny. I will get the cherry-picker so I can lift the front of the car high enough to slide the drivetrain out..
Sunday:
Whew !!!!! What a stressful operation out of one's garage. I was able, after a couple of trails and "well, that's not going to work" and a VERY slow-going mode of operation, to successfully remove the 440/727 drive train.. I was extra anal and slow about it all. I would assess a situation, come up with a solution, complete the task and clean up. I found keeping a clean and orderly workfloor made for a less chaotic event. There were a couple of times I wondered, "What the heck am I doing?" Shoot, one of the steps to remove the steering column, as easy as a task it is normally, turned out to be a big pain in the butt. Dang lock pin was NOT going to come out easily.... But, I prevailed.. One observation will be to get lower profile casters so the dolly won't be so high.... Now, time to replace fuel and brake lines, remove/replace brake booster ( hemi-version ) and etc.... I will separate the 727 soon and have it rebuilt. I am tired !!!! Church, lunch with the family, and 440 removal,, the end of a busy day.....
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552078
05/02/14 04:24 PM
05/02/14 04:24 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Troy I remember doing that a few years back by myself but I didn't have that big azz beak in the way!!!
Ron
Re: Hemi Transplant in my '69 Daytona [Re: RJS] #1552079
05/02/14 11:09 PM
05/02/14 11:09 PM
RI Deep in the rust belt
chargervert Online content
chargervert  Online Content
I like that yellow car in the backround. I used to have one just like that!
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: Hemi Transplant in my '69 Daytona [Re: chargervert] #1552080
05/26/14 07:24 PM
05/26/14 07:24 PM
Houston, Tx
Houston, Tx
Update time....
Been working on the car here and there...
Placed the hemi k-member on my dolly and positioned the hemi on it.
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552081
05/26/14 07:27 PM
05/26/14 07:27 PM
Houston, Tx
Houston, Tx
Another dolly. As some mentioned, I particularly didn't feel right about the dipstick tube positioned where I had it before, so rebend the tube and positioned it between 1 and 2 tubes. I believe this will be just right. It clears the steering gear box rather well. It also doesn't touch the tube, even with the white sheath on it. The gearbox is testing fitted right now, I will have to remove it to get the headers out so I can install the mini-starter once I mate the tranny. Then, I will install the 90 degree high pressure fitting on the gearbox
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552082
05/26/14 07:27 PM
05/26/14 07:27 PM
Houston, Tx
Houston, Tx
Positioning it...
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552083
05/26/14 07:30 PM
05/26/14 07:30 PM
Houston, Tx
Houston, Tx
Installed the hemi power brake booster assembly from Wayne.. Looks great. I have all new lines and valves as well.
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552084
05/26/14 07:31 PM
05/26/14 07:31 PM
Houston, Tx
Houston, Tx
Next thing was to tackle the front calipers. Man !!! I got into it and wow, what a mess...... It is amazing the things even worked.....
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552085
05/26/14 07:33 PM
05/26/14 07:33 PM
Houston, Tx
Houston, Tx
I found a COMPLETE front Bendix caliper rebuild kit to include all new pistons, seals and springs. Here I have one caliper all cleaned and honed.
http://www.harmonclassicbrakes.com/
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552086
05/26/14 07:35 PM
05/26/14 07:35 PM
Houston, Tx
Houston, Tx
Last of the brakes for awhile... I'll get new drum hardware later on and rebuild the wheel cylinders since they are the originals I believe. Regardless, I'll freshen them up. I also have a new set of pads. As you, I use the Blue Racing Brake Fluid due to the increased temperatures in the engine compartment of the Nose-cone car. I am hoping with the TTI ceramic coated ( internal and external ) and the exhaust being further down, my engine compartment temperatures will decrease substantially. Those cast iron 440 HP manifolds put out some heat...
The other thing I did was remove the OEM .92 original torsion bars and replaced them with the .96 MP versions. I'll duplicate the brown paint swabs on the torsion bars.
Troy
Re: Hemi Transplant in my '69 Daytona [Re: hemi68charger] #1552087
05/26/14 07:46 PM
05/26/14 07:46 PM
Houston, Texas
Slant6pak Offline
Slant6pak  Offline
Houston, Texas
Let us know how those work out for you. I need to upgrade the spindly stock bars in my Coronet and thinking about the .96 ones
2016 Challenger Scat Pack Shaker smile
1000 ci Brass Era Speedster project
