Re: Removing Undercoating
[Re: dart4forte]
#155115
11/22/08 08:25 PM
11/22/08 08:25 PM
340dart4spd
Parts Problem
Parts Problem
Anybody here ever use the Fein Multimaster tool with the ridgid scraper to remove undercoating?
putty knife and a torch,just keep torch moving....
[Re: 340dart4spd ]
#155117
11/22/08 08:56 PM
11/22/08 08:56 PM
Posts: 1,047 Arizona
68CoronetRT
Arizona
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: 68CoronetRT]
#155118
11/22/08 09:09 PM
11/22/08 09:09 PM
Posts: 1,320 Lees Summit, MO
BrianT
Lees Summit, MO
A buddy of mine used one of these when he stripped his Chevelle. It's a little pricey, but worked like a charm. He says it was worth every penny. Best part is, when I'm ready I can borrow it as long as I buy a new head for it. high $ Snap On toolI just looked at the sanding tool you were talking about and these are priced about the same. Your sander could obviously be used for other things, the Snap On tool is a uni-tasker.
1970 Duster 340 clone
[Re: whitemtnelf]
#155120
11/22/08 10:35 PM
11/22/08 10:35 PM
paint remover works the best
[Re: boydsdodge]
#155124
11/23/08 08:08 PM
11/23/08 08:08 PM
Posts: 16,169 Mesa, Arizona
dart4forte
Mesa, Arizona
I used a needle scaler on lots of areas. It worked great.
Okay, I give up, what is a needle scaler? In answer to leaving it on I'm running fenderwells so the area where the coating is will get hot. I'm leaving the coating in the upper fender well alone.
[Re: dart4forte]
#155125
11/23/08 08:17 PM
11/23/08 08:17 PM
340dart4spd
Parts Problem
Parts Problem
http://www.novatekco.com/html/needle_scalers.html
[Re: dart4forte]
#155127
11/23/08 08:30 PM
11/23/08 08:30 PM
340dart4spd
Parts Problem
Parts Problem
Thanks, bet that tool costs a bundle
It would not be my choice... I still prefer using a torch to soften undercoat .and a wide scraper to remove it...
[Re: 340dart4spd ]
#155130
11/24/08 12:14 AM
11/24/08 12:14 AM
Posts: 2,592 None
71rm23
None
I'm using a heat gun but a wide scraper as well. Mine seems to come off pretty easy, so far. While I'm on this subject and not to deviate from the OP but here's a question related to this:
What to put/do to the metal after removing the undercoating? I would think you need to do something soon to prevent anything happening to the metal. In my case, it could be a while to take it to a body shop(if that's the process)
[Re: dart4forte]
#155131
11/24/08 09:10 AM
11/24/08 09:10 AM
Challenger 1
Cincinnati, Ohio
If anyone is close to me, and your car is on a rotissierie. I will remove everything off the bottem of your car except for the paint in about 4 hours.You could bring the car to me or I could come to you.No scrape marks or gouges and no open flame used. PM me for the cost and availability. Quote: What to put/do to the metal after removing the undercoating? ![](/ubbthreads/images/graemlins/shruggy.gif) I would think you need to do something soon to prevent anything happening to the metal. In my case, it could be a while to take it to a body shop(if that's the process)
Normally the metal would be media blasted and then immediately primed and painted.
[Re: Challenger 1]
#155132
11/24/08 10:15 AM
11/24/08 10:15 AM
Posts: 3,318 Southern Maryland
klunick
Southern Maryland
I used a needle scaler also but I can see where it might not work with other cars. I had the black undercoating on the car(barracuda) that was hardened and it came off fine with a needle scaler. But, the 69 Superbee has the snot colored stuff on it that seems more gooey. If anyone chooses to use the needle scaler, spend the money and get the Ingersol Rand unit from Northern Tools. I used the one from Harbor freight and it lasted all of about 5 hours and the local store told me to pound sand on an exchange, it was a factory warranty. The two units look identical but the IR unit has lasted.
By the way, if anyone is near Challenger1, take him up on his offer for removal and media blasting. Both jobs are time consuming and well worth the money spent to have others do it better and faster.
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
[Re: Challenger 1]
#155133
11/24/08 12:48 PM
11/24/08 12:48 PM
Posts: 2,592 None
71rm23
None
I just might do that Challenger 1. I've seen what you have done to your car(s) and I'm impressed. It would be worth it to me to bring it to you or come up with other arrangements ![](/ubbthreads/images/graemlins/bow.gif)
