Re: Project 1972 D100 [Re: magnum440d100] #1548747
12/25/13 12:51 AM
12/25/13 12:51 AM
woodcrest, CA
magnum440d100 Offline OP
woodcrest, CA
Pushed it out into the gravel driveway and went to scrubbing. Had to stop. After all, it IS Christmas Eve lol
Found that both the motor mount ears on the Kmember are cracked. Pics later. This truck is looking like its going to need a K member bummer. Looks like its welded in.
Re: Project 1972 D100 [Re: magnum440d100] #1548748
12/30/13 11:44 PM
12/30/13 11:44 PM
woodcrest, CA
woodcrest, CA
More scrubbing.
Started taking the black spray paint off.
Re: Project 1972 D100 [Re: magnum440d100] #1828264
05/17/15 04:04 AM
05/17/15 04:04 AM
woodcrest, CA
woodcrest, CA
So, long time, no update.
One thing led to another, and well.....
Re: Project 1972 D100 [Re: magnum440d100] #1828266
05/17/15 04:07 AM
05/17/15 04:07 AM
woodcrest, CA
woodcrest, CA
Got the cab setting on there in this pic. Doing van LCA's, and installed PST suspension. Hope it lasts.
Re: Project 1972 D100 [Re: magnum440d100] #1828268
05/17/15 04:13 AM
05/17/15 04:13 AM
woodcrest, CA
woodcrest, CA
Have it semi assembled. Still no cab mounts. Saving up for them.
Still have to run brake lines, etc, but need it rolling for when my house sells. Plus now I can get my other truck backed in to pick up the 360 to take to get balanced smile tomorrow, I may do the brakes (upgraded to 11" in the rear and need to get the pads/cylinders/spring kit, etc.
Re: Project 1972 D100 [Re: magnum440d100] #2150174
09/08/16 05:09 AM
09/08/16 05:09 AM
woodcrest, CA
woodcrest, CA
Long time no update.
Been busy and haven't gotten to the truck as much as I would like.
BUT I got it running with a 318 for now. 360 build is going slow. I may assemble it soon but I'm waiting for heads.
Been working on the 72 every day for the past few days. Got it running and moving. Still needs some loose ends handled:
Strut rod bolts/sway bar bolts on control arm tightened
Attach sway bar end links
Wiring ran to tail lights
Cab bolts tightened all the way. Left loose to lift cab for panel alignment
Lube front end
Run exhaust. Right now it's just open Y pipe
Attach front bumper
And anything else that I come across. But I drove her out of the spot she's been sitting in. Can't do any work on it tomorrow, but Friday till Monday is open season laugh I can't wait hehe
Re: Project 1972 D100 [Re: magnum440d100] #2157166
09/19/16 01:05 AM
09/19/16 01:05 AM
tn
timeklr Offline
timeklr  Offline
tn
Looking good keep at it!!! I'm liking the stance reminds me of the old 1970's look
