9 1/4 Rear Axle #1547282
12/14/13 01:08 AM
12/14/13 01:08 AM
North Carolina
Mikeymopar68 Offline OP
North Carolina
Question: I was offered a complete 9 1/4 sure grip 3.55 rear axle out of a LRE. I can detect no slop/clunking when I turn the wheels and there is no apparent issues with it. Can anyone give me a fair and reasonable price for it? It also comes with the top mount pads and shock mounts. Thanks
Re: 9 1/4 Rear Axle [Re: Mikeymopar68] #1547283
12/14/13 01:30 AM
12/14/13 01:30 AM
N
NITROUSN Offline
NITROUSN  Offline
N
100.00 tops
Re: 9 1/4 Rear Axle [Re: Mikeymopar68] #1547284
12/14/13 02:04 AM
12/14/13 02:04 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
IIRC LREs never were available with Sure Grips...
I am truckless..
Re: 9 1/4 Rear Axle [Re: 340SHORTY] #1547285
12/14/13 03:18 AM
12/14/13 03:18 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
You had to order the sg. It was an option and not standard. $100-175
Re: 9 1/4 Rear Axle [Re: 76dodgeboy] #1547286
12/14/13 04:02 PM
12/14/13 04:02 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
You are talking about a rear end that is 35+ years old and unless the truck has never been driven from day one you have to go by what the condition is today.
On Wednesday a friend and I pulled a 8 3/4 housing with axles, brakes & drums, but no 3rd member at the local Pick-n-Pull and it was $150.00. This was out of a '56 Belvedere that had been treated to a 383 four speed transplant back in the day
Everything we got was very useable, the 10" drums still had chamfer, the brake shoes looked new and the hardware was new, the u-bolts were not rusty and will be re-used. The housing had been converted from keyed to flanged axles and they were good with recent Timken bearings, so you know it was not OEM. So as I see it, we got several hundred dollars of value for $150.00
And since this is going into a '55 Belvedere street rod, it all bolts up.
That is the real way to determine value
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 9 1/4 Rear Axle [Re: Polarapete] #1547287
12/14/13 08:24 PM
12/14/13 08:24 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
IMO a 9 1/4 will never have the value that an 8 3/4 will have..
I am truckless..
Re: 9 1/4 Rear Axle [Re: Mikeymopar68] #1547288
12/14/13 10:52 PM
12/14/13 10:52 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I've bought a few in the last couple of years. Going rate is $100 for a 3.55 Sure Grip.
Sheldon
Re: 9 1/4 Rear Axle [Re: RUNCHARGER] #1547289
12/15/13 01:13 AM
12/15/13 01:13 AM
Truckville, the capital of NY
85_Ram_4speed Offline
Myself and a buddy of mine have bought a couple of 9 1/4. I don't think neither of us have spent more than $100, I think I paid $75 for the one I still have that is going in my truck to replace the 8 1/4.
Outcast Dodge guy.
