Re: what can be done to a 360 for strength
[Re: BJS racing]
#1546735
12/13/13 12:08 AM
12/13/13 12:08 AM
Posts: 10,051 MI, usa
dvw
MI, usa
The biggest problem with the small block mopars are the main webs between the cam and the crank. They are not strong enough to support much over 600 - 650 HP. you will find people out there that have made more power than that and had no problems and some that haven't even made that much and had big problems. Main cap walk and the block its self are the biggest issues. A good main cap system (pro-grams) or something similar with studs and a good balance job are highly suggested.
I'm surprised at your findings. I've seen these problems with B/B but never a small block. I've never seen a small block pull a main web out like a B/B? Any pics? Split cylinder wall possibly. We've run boosted ones for years with no failures, Yet. Doug
[Re: dvw]
#1546736
12/13/13 12:21 AM
12/13/13 12:21 AM
Posts: 52,972 Romeo MI
MR_P_BODY
All I have done is split cyl walls... I have blown one up due to ripping a Viper rod in half.. they arent as strong as they said LOL.... never had any cap walk
[Re: mopar dave]
#1546740
12/13/13 02:31 AM
12/13/13 02:31 AM
Posts: 168 Moparts
SSDart
Moparts
what size jounal would you recommend and how is smaller safer?
Taking the journals down to 2" and using a chevy end connecting rod would be ideal..... the smaller journal has less surface speed plus think you can grind the crank with a generous radius making it much stronger again........... cost effective?? I'm not sure...
[Re: MR_P_BODY]
#1546741
12/13/13 02:33 AM
12/13/13 02:33 AM
Posts: 1,407 CA.
RAY1969CARS
CA.
You seem to have good package there, sounds very angry. I'm suprised it's not a little quicker. What does the car weigh ? and did that enormous carb pick the car's Performance up ? What is your pb ? Mick
My cam is all wrong... it should be a FAIR bit quicker but thats gonna be for someone else since I'm sellingg the car... I cant get a NHRA license any more... its been 8.96.... should be closer to 8.60 and the new cam should do it
why can't you get a NHRA license anymore
[Re: RAY1969CARS]
#1546743
12/13/13 10:41 AM
12/13/13 10:41 AM
MR_P_BODY
Health reasons
[Re: MR_P_BODY]
#1546744
12/13/13 10:50 AM
12/13/13 10:50 AM
Posts: 1,407 CA.
RAY1969CARS
CA.
Health reasons im so sorry bro !
[Re: TheOtherDodge]
#1546746
12/13/13 12:43 PM
12/13/13 12:43 PM
Posts: 3,210 robin hood country
deaks
robin hood country
No offence Mike but my comments were meant for the OP. Lol Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: qwkmopardan]
#1546750
12/13/13 02:04 PM
12/13/13 02:04 PM
Posts: 3,640 Oakland, MI
dizuster
Oakland, MI
Use ARP or stock head bolts. Use head studs and you will blow head gaskets.
I'd like to hear some logic behind that one. It flies in the face of common top engine builders best practices throughout the country.
Also, in my opinion a lot of the reason yours has lasted a long time is the fact that it's only got 28 degree's of timing in it.
Cylinder pressure early in the cycle puts an enormus stress on parts (and worse yet if it's detonating.) Remember if it's got a lot of cylinder pressure at TDC (or near it), it's trying harder to push the crank out the bottom of the block then it is trying to turn it!
[Re: mopar dave]
#1546752
12/13/13 02:16 PM
12/13/13 02:16 PM
Posts: 168 Moparts
SSDart
Moparts
haven't heard that before. I thought head studs created a better clamping force to help prevent head gasket blow out? i'm currently using the ARP head bolts. guess I could reuse these and save alittle.
I have not seen this on a Mopar, but on a small block ford the studs will pull up the surface locally around the stud... went through this with a 302 once. The cure is a MLS gasket.......
I looked up 2 inch pin rods....... lot's available in the chevy listings..... but they are .927 pin.. not the cheapest route but more reliable........
[Re: dizuster]
#1546753
12/13/13 02:19 PM
12/13/13 02:19 PM
dartman366
Mt. Vernon, Ohio
bback when I was running the old 366 I would blow a head gasket once in a while using stock head bolts,switched over to ARP head bolts and problem went away, my opinion is the stock head bolts are too soft and will stretch too much under pressure, my opinion is use a good quality ARP head bolt at the very least on a cast iron head and head stud's on aluminim heads.
