Re: what can be done to a 360 for strength
[Re: mopar dave]
#1546775
12/14/13 01:21 PM
12/14/13 01:21 PM
Posts: 3,429 Toronto
mshred
Toronto
I would like to use a short CH piston to get it real lite. I really want to science this build out as it will be my last go fast build and chance to break into the 9's. the next one after that will be a bb stroker just for cruising and to show. gonna get away from chasing numbers and sell my trailer as well. anyway I really want to get this sb right this time around.
My , I would sell what you have, build a BB pump gas stroker that will be able to cruise around and run 9's ...I don't see the point in spending all the money twice on the SB when you are going to go BB in the end and be able to reach your goals
[Re: barracuda man]
#1546778
12/14/13 02:40 PM
12/14/13 02:40 PM
Posts: 20,207 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I'm sorry but I have no pictures at this time. I always did mine by hand with a carbide burr but that's just me. I would try it first on a piece of scrap metal to get some practice. Remember its not a big crazy chamfer. For example on a small block head ( 1/2 inch bolt ) its only gonna be like 3/16 - 1/4 inch max 45 degree chamfer. Just enough to spread the pressure from directly under the bolt head.
[Re: Thumperdart]
#1546784
12/14/13 06:23 PM
12/14/13 06:23 PM
Posts: 11,733 Portage,michigan
B3422W5
Portage,michigan
Disagree about a long rod killing off power, that isn't true at all. In fact the guy who owns my old car has been 9.62 at 140 with it at 3200 pounds on super stock springs and 28by 10 DOT tires. That is with off the shelf headers and a 727 trans. Don't know of many, if any, similar W5/ Indy combo's that run any better.
To the OP, we're it me I would mill the heads if you have flat tops to raise compression, run a cam to match the compression, and swap the 727 you have already for a 904 . The tranny swap should be good for 1.5 tenths, and a little more cam and compression will knock another 2 or 3 tenths out of it easily. I would be willing to bet another another point in compression( to 12.5 compression) the correct cam, and the 904 would get the car into the 9's. This all assumes the heads are good. If anything those heads have a bit more potential than W5 head, which has smaller valves and less cross section. Doesn't take anything special to get an A body in the 9's with a roller and Indy heads
[Re: B3422W5]
#1546785
12/14/13 09:08 PM
12/14/13 09:08 PM
Thumperdart
State of confusion
Good running combo 4 sure.............. Can that car be driven the said 700 miles round trip? ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Thumperdart]
#1546786
12/15/13 12:08 AM
12/15/13 12:08 AM
B3422W5
Portage,michigan
Lol..... No..... The cam in it now is a spring eater..... The milder one I ran I drove around on the street some, but I only ran the numbers in my signature..... ![](/ubbthreads/images/graemlins/biggrin.gif)
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: B3422W5]
#1546787
12/15/13 09:12 AM
12/15/13 09:12 AM
Posts: 168 Moparts
SSDart
Moparts
When I originally joined in on this thread, I thought the OP was building a stock stroke 360......... The long rod would be brutal in that...
