Re: organisol paint   PPG Concept version [Re: demon] #1546175
12/13/13 04:45 PM
12/13/13 04:45 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
I will toss in some common sense on this as well,
This Laquer paint must have been applied by hand in an off line spray area, since the cars used baked enamel. and the enamel had to be baked first so it could be masked.
this means all the different plants had at least 3 shifts of people painting differently with faily low volume production runs of paint, with possible different air pressure, paint mixes and equipment..done by hand..
The possible "correct" variations are endless.
you are right about that. And that applies to many situations on old cars. There are variations.
As an example, on the Charger R/T I restored a few years ago, when I pulled out the taillights, and looked at the virgin Organosol paint that had been hidden and untouched for 40 years, it had no texture.
The original paint 69 Road Runner that I bought from the original owner had the factory hood blackout stripes. Around the edges and hidden areas like under the windshield trim, no texture.
I'm not saying there weren't cases of factory Organosol with texture, but I am saying that I have seen AAR Cudas and othe cars at shows where the hood looks like 80 grit sandpaper and I have never seen an original Organosol finish that was that rough.
But! As was said above, these were production line cars, and car to car variations definitely occur.
St. Louis Chargers didn't use Organosol which is also stated per the engineering....I guess St. Louis already had lacquer restraints....just a little tid-bit to share...
Re: organisol paint   PPG Concept version [Re: FJ5_Fish] #1546176
12/13/13 08:47 PM
12/13/13 08:47 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Correct, starting in May 1968 low gloss black enamel was used
Re: organisol paint   PPG Concept version [Re: DAYCLONA] #1546177
12/13/13 11:31 PM
12/13/13 11:31 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
A fresh coat of organisol. It is more textured than it appears.
Re: organisol paint   PPG Concept version [Re: moparcanuk] #1546178
12/14/13 04:03 AM
12/14/13 04:03 AM
South Dakota
hotairballoonpilot Offline OP
South Dakota
Well that's a lot of info! Thanks guys! My main concern was being so rough that a person couldn't wax or anything near it. I'm ok working to get it close to that 600-1000 grit level. Looked at the color spray out and you can barely see the metallic.
Contact Me about AMD Prices
Re: organisol paint   PPG Concept version [Re: hotairballoonpilot] #1546179
12/14/13 12:03 PM
12/14/13 12:03 PM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
I don't wax mine, I wax around it.
Re: organisol paint   PPG Concept version [Re: hotairballoonpilot] #1546180
12/14/13 12:51 PM
12/14/13 12:51 PM
South Dakota
South Dakota
I should clarify my wax statement. I was worried about waxing around it and wax getting on it not by choice.
Re: organisol paint   PPG Concept version [Re: hotairballoonpilot] #1546181
12/16/13 11:02 AM
12/16/13 11:02 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
You MUST keep wax far away from it or you will have to sand and reshoot! DAMHIK
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
