Re: Header bolt leaks water [Re: Tommy D] #1545930
12/10/13 06:52 PM
12/10/13 06:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have always found its easier to treat the leak from
the inside from where the leak starts from instead
of stopping the leak from the outside... thats why
I use the stop leak... hasnt failed yet... once its
stopped it hasnt come back even if you pull the bolt
(but on big blocks I always use a high temp silicone)
if I pull the bolts
Re: Header bolt leaks water [Re: Tommy D] #1545931
12/10/13 07:30 PM
12/10/13 07:30 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
When I put my helicoils in, I put red silicone the outsides first before I wound them in, but everyone I know has done them successfully with silicone just on the bolt. Im gonna say the pipe dope is keeping from a clean seal.
Re: Header bolt leaks water [Re: Hot 340] #1545932
12/10/13 07:55 PM
12/10/13 07:55 PM
California
mickm Offline
mickm  Offline
California
that's what i did in mine, put a plug with sealer on it down far enough for the header bolt to go all the way in.
proverbial 2 birds with 1 stone: not only does it not leak, but it doesn't spill water all over me when i need to take it out!
Re: Header bolt leaks water [Re: Tommy D] #1545933
12/10/13 10:11 PM
12/10/13 10:11 PM
long island new york
K
kingdust Offline
kingdust  Offline
K
Thanks to all. I have allowed 24 plus hours for the RTV to cure. The garage was cold though. I think I'll try Mark's idea with the copper Permatex. Sending the headers out to be coated now. Will install after the Holiday. I appreciate all the help from the folks on this site. Merry Christmas. Tom
the ultra copper will work but the set screw trick is FOREVER! happy holidays. MARK
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: Header bolt leaks water [Re: mickm] #1545934
12/10/13 11:43 PM
12/10/13 11:43 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
I like this idea and am going to do it to my 383 next time I pull the headers.
Of course there's always aluminum heads with blind holes... It was nice to not have to worry about this, maybe I should put the Bulldogs on the 383
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Header bolt leaks water [Re: Sledge_57] #1545935
12/11/13 04:19 PM
12/11/13 04:19 PM
California
mickm Offline
mickm  Offline
California
not familiar with bulldogs, but just the big grin alone would make me say go for it!
Re: Header bolt leaks water [Re: MR_P_BODY] #1545936
12/11/13 06:45 PM
12/11/13 06:45 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
if I pull the bolts
Why are we even considering bolts when studs stay put and don`t have to be sealed every time they`re removed.........
Re: Header bolt leaks water [Re: Thumperdart] #1545937
12/11/13 06:46 PM
12/11/13 06:46 PM
California
mickm Offline
mickm  Offline
California
i think the OP mentioned that studs aren't an option. space considerations i'm assuming.
Re: Header bolt leaks water [Re: mickm] #1545938
12/11/13 06:50 PM
12/11/13 06:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My blind ass missed that part............
Re: Header bolt leaks water [Re: Thumperdart] #1545939
12/11/13 07:13 PM
12/11/13 07:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
if I pull the bolts
Pretty simple... he said he doesnt have the room
for the studs and get the headers on and off with them
Re: Header bolt leaks water [Re: MR_P_BODY] #1545940
12/11/13 08:41 PM
12/11/13 08:41 PM
gregsdart Online content
gregsdart  Online Content
Just off the top of my head I thought of running an allen plug(set screw?) into the bolt hole, then pack it with some form of hi temp sealent and run a bolt in after that to force it into the helicoils? Let it set up a bit, remove the bolt and plug and hopefully it will hold, if you use more hi temp silicon on the bolt threads.
Re: Header bolt leaks water [Re: gregsdart] #1545941
12/11/13 09:45 PM
12/11/13 09:45 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That might work but looking back, I recall there not being much thread depth IIRC...............
Re: Header bolt leaks water [Re: an8sec70cuda] #1545942
12/11/13 11:56 PM
12/11/13 11:56 PM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
I think the problem is that the leak is coming from around the heli coil thread not the header bolt. That is going to be a problem as the pipe dope sealant used will continue to erode and remain leaking. I would try a good stop leak first , if that doesn't work then you might have to drill out the coils and screw them back in after cleaning the holes. Use the proper epoxy that will take heat.
Or use a solid threaded insert.
X3!
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: Header bolt leaks water [Re: 1KoolBee] #1545943
12/12/13 03:44 AM
12/12/13 03:44 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
X3!
I guess I don't know what a solid threaded insert is, please explain . Coils aren't very deep, trying to plug the end wouldn't give you much thread either way to work with.
Re: Header bolt leaks water [Re: rowin4] #1545944
12/12/13 05:52 PM
12/12/13 05:52 PM
Harleysville, PA USA
Tommy D Offline OP
Tommy D  Offline OP
Headers are shipping out to be coated today. I appreciate all the suggestions. I'll post the results when the headers return from coating. Should be sometime after New Years. Thanks again for your help.
Re: Header bolt leaks water [Re: rowin4] #1545945
12/13/13 12:24 AM
12/13/13 12:24 AM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
Here's a link to some self sealing solid inserts:
http://www.mscdirect.com/product/05980594?fromRR=Y
Also, you could try JB welding in the helicoils as well. If everything is clean it should hold fine, just let it cure a couple days. It seems to handle heat real well. I JB welded a check valve onto a smog tube once as a temp fix to get my old truck to pass smog, it was hard as a rock and still holding 6 years later!
Re: Header bolt leaks water [Re: 1KoolBee] #1545946
12/13/13 12:55 AM
12/13/13 12:55 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
We used these on our max wedge heads: Time Sert
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Header bolt leaks water [Re: 1KoolBee] #1545947
12/13/13 10:43 AM
12/13/13 10:43 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
These are the inserts I was referring to. I just added a little extra teflon paste to them when I put them in (probably not needed, but made me feel better) and let it set up over night. Had to do several of the header bolt threads on the 906 heads in my dad's road runner. That was about 4 years ago...no leaks.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Header bolt leaks water [Re: Thumperdart] #1545948
12/13/13 11:13 AM
12/13/13 11:13 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
My only big block experience was with the RB in the Mirada and I can personally say that studs would have made header install/removal impossible.
Re: Header bolt leaks water [Re: J_BODY] #1545949
12/13/13 01:41 PM
12/13/13 01:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I can see that in some cases but w/fenderwells, that`s not a problem.
