Header bolt leaks water #1545910
12/10/13 08:28 AM
12/10/13 08:28 AM
Harleysville, PA USA
Tommy D Offline OP
Tommy D  Offline OP
Looking for help or ideas to seal headers to heads. I have a set of modified 452 heads on my Road Runner's 440. I recently replaced my headers with a new set of Doug's. During replacement, i found that the threads on the driver's side head were pretty far gone. Through the advise of a friend I reluctantly heli-coiled the header bolt holes. Since repairing, I have been unsuccessful in sealing the coolant. I do not have enough room to run studs. Any ideas on sealing the leaks?? I've tried pipe dope, and even silicone RTV. The RTV seemed to seal better than the pipe dope, but I still have a trickling leak. Tom
Re: Header bolt leaks water [Re: Tommy D] #1545911
12/10/13 08:32 AM
12/10/13 08:32 AM
Q
Quicktree Offline
Quicktree  Offline
Q
just put a little silicone on the bolt.
Re: Header bolt leaks water [Re: Tommy D] #1545912
12/10/13 08:33 AM
12/10/13 08:33 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
We have used thread tape with good results. Don't know if it would help you but worth a try ! The also sell the copper RTV that my brother says works, but I have not tried it.
Re: Header bolt leaks water [Re: Tommy D] #1545913
12/10/13 10:23 AM
12/10/13 10:23 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
take it you didn't put any epoxy in the holes when you installed the heli coils. This might be a tough one to seal.
Re: Header bolt leaks water [Re: J_BODY] #1545914
12/10/13 10:39 AM
12/10/13 10:39 AM
Tommy D Offline OP
Tommy D  Offline OP
I did not use epoxy when installing the heli-coils, but I did use pipe dope. It sealed, but once the engine got up to temp and the system pressurized, the leaks started. I took the pipes off and cleaned the bolt holes as good as I could. I then used black Permatex on the bolts. That worked ok for a bit, but started to seep shortly thereafter.
Re: Header bolt leaks water [Re: Tommy D] #1545915
12/10/13 10:42 AM
12/10/13 10:42 AM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Have you tried the green pipe dope ? That is for hi temp.
Re: Header bolt leaks water [Re: drew72] #1545916
12/10/13 10:56 AM
12/10/13 10:56 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Use Dike sealer by Conklin.Add to coolant and circulate under normal cooling pressure for 10 minutes
Re: Header bolt leaks water [Re: drew72] #1545917
12/10/13 10:56 AM
12/10/13 10:56 AM
long island new york
K
kingdust Offline
kingdust  Offline
K
drain all the water out again and seal the bolts with permatex (ultra copper) silicone. put it back together but don't put any water or antifreeze in it till the next day, let the silicone set up and harden. problem solved! what I do on factory heads is I install small 1/4 allen head set screws in the bolt holes and use a slightly smaller header bolt and the water wont come out when you take the header off and make a mess. good luck. mark
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: Header bolt leaks water [Re: Tommy D] #1545918
12/10/13 11:11 AM
12/10/13 11:11 AM
Az
Crizila Offline
Crizila  Offline
Az
Hardening Permatex on the bolt threads. Don't know what you are running for a rad pressure cap, but you could try dropping it down to 7 or 10 lbs.
Fastest 300
Re: Header bolt leaks water [Re: Crizila] #1545919
12/10/13 12:44 PM
12/10/13 12:44 PM
Tommy D Offline OP
Tommy D  Offline OP
I just checked the radiator cap I recently purchased from Year One. It is a 16LB cap!! Is this a part of my problem? In one of the earlier responses cap pressure was brought up. I may have to go back to the old Stant piece from NAPA? Any thoughts are appreciated...and thanks for all the help so far. TD
Re: Header bolt leaks water [Re: Tommy D] #1545920
12/10/13 12:52 PM
12/10/13 12:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just use Stop Leak in the cooling system... I use
that in every fresh build... the high pressure cap
does raise the boiling point but if you have a good
cooling system you dont need it that high
Re: Header bolt leaks water [Re: MR_P_BODY] #1545921
12/10/13 12:58 PM
12/10/13 12:58 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I had a seep and used the little round 1" puck shaped stop leak sealed right up.
Re: Header bolt leaks water [Re: Tommy D] #1545922
12/10/13 12:59 PM
12/10/13 12:59 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
....have you let that rtv cure for 24 hours or so ?
Re: Header bolt leaks water [Re: Tommy D] #1545923
12/10/13 01:12 PM
12/10/13 01:12 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
ARP studs and sealant...............gone forever.
Re: Header bolt leaks water [Re: Thumperdart] #1545924
12/10/13 01:28 PM
12/10/13 01:28 PM
P
Paul_Fancsali Offline
P
Do not do the job in a unheated garage below 55 degrees or so if you must to cure the silicone use a quick hit with a heat gun
Re: Header bolt leaks water [Re: Paul_Fancsali] #1545925
12/10/13 01:40 PM
12/10/13 01:40 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I think the problem is that the leak is coming from around the heli coil thread not the header bolt. That is going to be a problem as the pipe dope sealant used will continue to erode and remain leaking. I would try a good stop leak first , if that doesn't work then you might have to drill out the coils and screw them back in after cleaning the holes. Use the proper epoxy that will take heat.
Re: Header bolt leaks water [Re: rowin4] #1545926
12/10/13 01:43 PM
12/10/13 01:43 PM
an8sec70cuda Offline
Or use a solid threaded insert.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Header bolt leaks water [Re: an8sec70cuda] #1545927
12/10/13 03:18 PM
12/10/13 03:18 PM
Tommy D Offline OP
Tommy D  Offline OP
Thanks to all. I have allowed 24 plus hours for the RTV to cure. The garage was cold though. I think I'll try Mark's idea with the copper Permatex. Sending the headers out to be coated now. Will install after the Holiday. I appreciate all the help from the folks on this site. Merry Christmas. Tom
Re: Header bolt leaks water [Re: Tommy D] #1545928
12/10/13 03:29 PM
12/10/13 03:29 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
On small blocks I've used set screws with sealant on them just far enough in to where it doesn't interfere with the bolts. Then it doesn't leak when you take the bolts out!
Back in the swing of things at Painless again! Great to be back!
Re: Header bolt leaks water [Re: BJS racing] #1545929
12/10/13 03:41 PM
12/10/13 03:41 PM
Tommy D Offline OP
Tommy D  Offline OP
That's a good idea. I may give that a try as well. You're the second to suggest it. The coolant is always an extra, step.
