Re: Header bolt leaks water
[Re: Tommy D]
#1545918
12/10/13 11:11 AM
12/10/13 11:11 AM
Posts: 7,506 Az
Crizila
Az
Hardening Permatex on the bolt threads. Don't know what you are running for a rad pressure cap, but you could try dropping it down to 7 or 10 lbs.
Fastest 300
[Re: Tommy D]
#1545920
12/10/13 12:52 PM
12/10/13 12:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I just use Stop Leak in the cooling system... I use that in every fresh build... the high pressure cap does raise the boiling point but if you have a good cooling system you dont need it that high
[Re: MR_P_BODY]
#1545921
12/10/13 12:58 PM
12/10/13 12:58 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
I had a seep and used the little round 1" puck shaped stop leak sealed right up.
[Re: Tommy D]
#1545922
12/10/13 12:59 PM
12/10/13 12:59 PM
Posts: 30,496 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
and even silicone RTV. The RTV seemed to seal better than the pipe dope, but I still have a trickling leak. Tom
....have you let that rtv cure for 24 hours or so ?
[Re: rowin4]
#1545926
12/10/13 01:43 PM
12/10/13 01:43 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
I think the problem is that the leak is coming from around the heli coil thread not the header bolt. That is going to be a problem as the pipe dope sealant used will continue to erode and remain leaking. I would try a good stop leak first , if that doesn't work then you might have to drill out the coils and screw them back in after cleaning the holes. Use the proper epoxy that will take heat.
Or use a solid threaded insert.
[Re: Tommy D]
#1545928
12/10/13 03:29 PM
12/10/13 03:29 PM
Posts: 2,224 Arlington, Tx.
BJS racing
Arlington, Tx.
On small blocks I've used set screws with sealant on them just far enough in to where it doesn't interfere with the bolts. Then it doesn't leak when you take the bolts out!
Back in the swing of things at Painless again! Great to be back!
