Re: Header bolt leaks water
[Re: Tommy D]
#1545930
12/10/13 06:52 PM
12/10/13 06:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have always found its easier to treat the leak from the inside from where the leak starts from instead of stopping the leak from the outside... thats why I use the stop leak... hasnt failed yet... once its stopped it hasnt come back even if you pull the bolt (but on big blocks I always use a high temp silicone) if I pull the bolts
[Re: Sledge_57]
#1545935
12/11/13 04:19 PM
12/11/13 04:19 PM
Posts: 4,179 California
mickm
California
Of course there's always aluminum heads with blind holes... It was nice to not have to worry about this, maybe I should put the Bulldogs on the 383
not familiar with bulldogs, but just the big grin alone would make me say go for it!
[Re: Thumperdart]
#1545937
12/11/13 06:46 PM
12/11/13 06:46 PM
mickm
California
Why are we even considering bolts when studs stay put and don`t have to be sealed every time they`re removed.........
i think the OP mentioned that studs aren't an option. space considerations i'm assuming.
[Re: Thumperdart]
#1545939
12/11/13 07:13 PM
12/11/13 07:13 PM
MR_P_BODY
Pretty simple... he said he doesnt have the room for the studs and get the headers on and off with them
[Re: MR_P_BODY]
#1545940
12/11/13 08:41 PM
12/11/13 08:41 PM
Posts: 10,034 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Just off the top of my head I thought of running an allen plug(set screw?) into the bolt hole, then pack it with some form of hi temp sealent and run a bolt in after that to force it into the helicoils? Let it set up a bit, remove the bolt and plug and hopefully it will hold, if you use more hi temp silicon on the bolt threads.
[Re: 1KoolBee]
#1545943
12/12/13 03:44 AM
12/12/13 03:44 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I think the problem is that the leak is coming from around the heli coil thread not the header bolt. That is going to be a problem as the pipe dope sealant used will continue to erode and remain leaking. I would try a good stop leak first , if that doesn't work then you might have to drill out the coils and screw them back in after cleaning the holes. Use the proper epoxy that will take heat.
Or use a solid threaded insert.
X3!
I guess I don't know what a solid threaded insert is, please explain . Coils aren't very deep, trying to plug the end wouldn't give you much thread either way to work with.
[Re: rowin4]
#1545945
12/13/13 12:24 AM
12/13/13 12:24 AM
Posts: 257 Way North Idaho
1KoolBee
Way North Idaho
Here's a link to some self sealing solid inserts: http://www.mscdirect.com/product/05980594?fromRR=YAlso, you could try JB welding in the helicoils as well. If everything is clean it should hold fine, just let it cure a couple days. It seems to handle heat real well. I JB welded a check valve onto a smog tube once as a temp fix to get my old truck to pass smog, it was hard as a rock and still holding 6 years later!
'68 Bee 383/TF/Factory Air...high school sweetheart '67 GTX Clone project,500 six pack,Hemi4-speed,Dana 05 Dodge Viper, 505 V-10, 6-speed Tremec
[Re: 1KoolBee]
#1545946
12/13/13 12:55 AM
12/13/13 12:55 AM
Posts: 1,443 Maryland
Dads426
Maryland
We used these on our max wedge heads: Time Sert
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: 1KoolBee]
#1545947
12/13/13 10:43 AM
12/13/13 10:43 AM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
These are the inserts I was referring to. I just added a little extra teflon paste to them when I put them in (probably not needed, but made me feel better) and let it set up over night. Had to do several of the header bolt threads on the 906 heads in my dad's road runner. That was about 4 years ago...no leaks.
[Re: Thumperdart]
#1545948
12/13/13 11:13 AM
12/13/13 11:13 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
My only big block experience was with the RB in the Mirada and I can personally say that studs would have made header install/removal impossible.
