Re: looking for pics of jesel small block belt drive [Re: 340Cuda] #1544312
12/08/13 01:15 PM
12/08/13 01:15 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
I have the Weber spacers and belt drive, My spacers have places to hook 2 water hoses to. I made an 8an go to the side of the block between 5/7 and 6/8, Then ran a 6an to the center of each head below the exhaust port.
Re: looking for pics of jesel small block belt drive [Re: SB412DUSTER] #1544313
12/08/13 04:51 PM
12/08/13 04:51 PM
Out West
408strokerdart Offline
Out West
After studying the two systems for some time....I'm not confident that one spacer design will work for both a Weber drive and a Jesel drive. The Weber design is more versatile for options of water pump use and front distributor use than the Jesel. The Jesel drive uses the top block mounting hole for the front mount distributor drive and this takes away from the ability to put a spacer on that will seal to the water inlet. No doubt that Jesel didn't understand what they were doing.....they should have just left their cover plate with no water passage and just forced a remote pump and inlet thru the core plugs. Weber gave you the option to do either. With that said, I personally like the remote pump as I can get to my spyder gear for adjustment without having to remove anything and can see straight on how much I moved the timing. Anyway, I have decided to make a run of spacers that will fit the Weber system. I guess if you go Jesel (like I did) then you will have fewer options for the water pump. Here are a couple of renderings of what the spacers will look like (with the addition of two ports that can be utilized in addition to the front port that lines up with the water pump).
Re: looking for pics of jesel small block belt drive [Re: 408strokerdart] #1544314
12/08/13 09:21 PM
12/08/13 09:21 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
^^^ that's sexy
Re: looking for pics of jesel small block belt drive [Re: fishy340] #1544315
12/09/13 03:00 AM
12/09/13 03:00 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Looks really good Brian
Re: looking for pics of jesel small block belt drive [Re: tubtar] #1544316
12/09/13 10:49 AM
12/09/13 10:49 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I used this pump........no worries about timing cover , spacers etc.
Ryan at Shady Dell had the aluminum core plugs that are threaded for 3/4 NPT and went with -12 line into each center core plug.
One benefit was that I had a lot of options for where to locate it.
I don't have a pic yet , but it is just below the outlet on the radiator and maybe 8" back , so a short 1 3/4 "L" of radiator hose was all I needed to get it fed.
The 55 GPM might be a bit generous , but the stat will help there I think. I am pretty sure they make a 35 GPM in the same configuration.
http://www.meziere.com/ps-1134-1102-wp316s.aspx
Can you change the inlet to a an fitting? I don't like regular rad hoses on my race motor.
Re: looking for pics of jesel small block belt drive [Re: 1967dartgt] #1544317
12/09/13 01:31 PM
12/09/13 01:31 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Kinda hard to see in the pic but Albert Racing Engines in Wytheville, Va. modified my existing MP (Arrow?) timing cover for use the Weber belt drive on my old turbo 9.20" deck R3/W8 combo.
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: looking for pics of jesel small block belt drive [Re: Plumb Wired] #1544318
12/09/13 01:46 PM
12/09/13 01:46 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Mike Gray
This Albert racing engines is getting more popular...Been hearing very good things.
