Re: looking for pics of jesel small block belt drive
[Re: tubtar]
#1544316
12/09/13 10:49 AM
12/09/13 10:49 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I used this pump........no worries about timing cover , spacers etc. Ryan at Shady Dell had the aluminum core plugs that are threaded for 3/4 NPT and went with -12 line into each center core plug. One benefit was that I had a lot of options for where to locate it. I don't have a pic yet , but it is just below the outlet on the radiator and maybe 8" back , so a short 1 3/4 "L" of radiator hose was all I needed to get it fed. The 55 GPM might be a bit generous , but the stat will help there I think. I am pretty sure they make a 35 GPM in the same configuration. http://www.meziere.com/ps-1134-1102-wp316s.aspx
Can you change the inlet to a an fitting? I don't like regular rad hoses on my race motor.
[Re: 1967dartgt]
#1544317
12/09/13 01:31 PM
12/09/13 01:31 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Kinda hard to see in the pic but Albert Racing Engines in Wytheville, Va. modified my existing MP (Arrow?) timing cover for use the Weber belt drive on my old turbo 9.20" deck R3/W8 combo. Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Plumb Wired]
#1544318
12/09/13 01:46 PM
12/09/13 01:46 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
Mike Gray
This Albert racing engines is getting more popular...Been hearing very good things.
