Roller pilot bearing how to remove it from the crank.
#1543587
12/04/13 02:20 PM
12/04/13 02:20 PM
Posts: 768 Maryville tn
67coronetman
Maryville tn
Roller pilot bearing how to remove it from the crank ?
Re: Roller pilot bearing how to remove it from the crank...
[Re: 67coronetman]
#1543588
12/04/13 02:24 PM
12/04/13 02:24 PM
dogdays
[Re: scatpacktom]
#1543591
12/04/13 02:46 PM
12/04/13 02:46 PM
67coronetman
Maryville tn
I am trying that sucker is in tight.. Quote:
Pack the hole with grease and get a shaft the same size as the pilot bearing. Put the shaft in the hole and whack it with a hammer
Old car are me......
[Re: scatpacktom]
#1543592
12/04/13 02:49 PM
12/04/13 02:49 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Done that beaucoup times over the years-with a bushing...
Never tried it with a bearing...
[Re: scatpacktom]
#1543595
12/04/13 03:10 PM
12/04/13 03:10 PM
67coronetman
Maryville tn
I am still trying i seen a guy on youtube use bread so i am trying that... Quote:
All I can say is that is the only way I have ever done it. Sometimes it has taken a few tries
[Re: 67coronetman]
#1543597
12/04/13 03:44 PM
12/04/13 03:44 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You're aware that the bearing is pressed into an adapter ring and all of the methods listed might just push out the bearing...leaving the adapter ring?
[Re: 80fbody]
#1543599
12/04/13 05:20 PM
12/04/13 05:20 PM
67coronetman
Maryville tn
That is what i did for the most part i did employ my head porting stuff to cut area to weaking it and i got it out that really sucked. Quote:
Could just beat it out with a chisel too. Not really worried about re-using it I'm sure. Can't really screw up anything back there.
[Re: Challenger 1]
#1543601
12/04/13 06:42 PM
12/04/13 06:42 PM
dogdays
[Re: dogdays]
#1543602
12/04/13 08:06 PM
12/04/13 08:06 PM
Challenger 1
Cincinnati, Ohio
Hey, bearing pullers!
R.
I know you suggested one above. Thought I'd show what one looks like.
I have internal 3 jaw puller too for it.
Invested in that small snap on puller set many years ago and it has paid for it's self many times over by now.
Also have a large set.
[Re: dogdays]
#1543605
12/05/13 12:52 PM
12/05/13 12:52 PM
67coronetman
Maryville tn
Re: Roller pilot bearing how to remove it from the crank... *DELETED*
[Re: 67coronetman]
#1543606
12/05/13 01:08 PM
12/05/13 01:08 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Post deleted by 67coronetman
Good job, that will really help anyone else who has a similar problem.
