Re: Sreet/strip guys...mechanical fuel pump??
[Re: Mopar Guy]
#1543434
12/05/13 11:37 AM
12/05/13 11:37 AM
Posts: 3,818 Arlington, Texas
bobby66
Arlington, Texas
CV makes a billet pump for Nascar that fits bb that i found and i gues that that would be one of the nasty once that will need a regulator but i havent tryed mine yet !
Where would I get one of these? I run the Clay Smith pump now, like to try something different in the future.
[Re: Mr.Yuck]
#1543435
12/05/13 11:40 AM
12/05/13 11:40 AM
BradH
In any even the carter and holley pumps will get a BB car well into the 11's w/o an issue, even w/ tiny 5/16 line.
Yep. IIRC, Dwayne Porter's 440 B-body was in the mid-to-high 10s w/ a mechanical pump and still had the OEM 5/16" line.
My only concern w/ a mechanical pump was when I was still running a Six Pack on The MoPig and had some vapor-lock problems crop up on occasion. The fuel line insulation I added to deal with the issue seemed to work, but certainly took away from the sleeper image.
[Re: Mopar Guy]
#1543436
12/05/13 03:50 PM
12/05/13 03:50 PM
Posts: 298 mt. pleasant, PA
Diplomat440
mt. pleasant, PA
i picked up one of these my self awhile back and have yet to use it. any body using one of these? i may try mine on a turbo project. [image][/image]
[Re: Diplomat440]
#1543439
12/06/13 10:35 AM
12/06/13 10:35 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
It will work as long as you can boost reference it. I ran a hi-po carter on my old S/C'd 440. All I did was tap a small 1/4 line into the top of the pump (it's already there maybe for venting)and ran a line from the head unit to the pump.
