Re: Used Cam Break in?? [Re: dOOc] #1543077
12/04/13 12:53 PM
12/04/13 12:53 PM
dogdays Offline
dogdays  Offline
BTW, "concave going out" is called "convex".
The base Edelbrock Performer cam is something like 204/204 @ 50 lift, 0.420 or 0.425 lift, it is really one step over stock 360 cam and should be a really nice cam for basically stock 318.
So it's a mild cam and will work with stock springs.
I think there's a really good chance that it'll just slap together and run. Here's a few suggestions:
Test fit the lifters in the holes. You don't want a tight lifter in the bore. You may have to swap them around so every lifter will move easily in the bore.
Make sure the outside surfaces of the lifter are free of varnish and lubricate them with motor oil. Don't put cam assembly lube on the sides of the lifters.
Back in the day, some chevy lifters came out of the box with "too shiny" a surface. It was recommended to spin them and lightly tough the end with 1000 grit, IIRC, wet-or-dry paper.
To be sure the ends are still convex, put two lifters end-to-end and rock them. If they rock they're OK, still convex. If not toss'em.
Lifter quality may be improving, but there are enough substandard lifters floating around in the food chain that I'd rather use a known quantity (existing lifters).
Use cam assembly lube on the camshaft and bottom of lifters.
Make sure the engine fires right up, then do the cam break-in.
It occurs to me that when the factory test-fired the engine they didn't use any specific method to break in the lifters.
R.
Re: Used Cam Break in?? [Re: dogdays] #1543078
12/05/13 10:30 AM
12/05/13 10:30 AM
MA
dodge413 Offline OP
dodge413  Offline OP
MA
Thanks Again For Everybodys Imput. Nobody Wants To Use Second Hand Parts, It's Easy To Just Say Buy New Parts, But The Way The Economy Is These Days There Isn't Extra Money Floating Around For The Fun Projects. I'm Sure I'm Not The Only One Trying To Still Have Fun While On A Budget. So Thanks Again For Helping Me Out!!
Re: Used Cam Break in?? [Re: dodge413] #1543079
12/05/13 10:47 AM
12/05/13 10:47 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
AMEN!!!
Even if the lifters were kept in order - putting them in a different block throws that all out of wack. I say treat it like a new set up with cam lube and break in and go for it. I would make sure that there is no rotators on the exhaust valves and if there is replace them with standard springs and retainers.
Re: Used Cam Break in?? [Re: MoparforLife] #1543080
12/05/13 01:44 PM
12/05/13 01:44 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
HOW MUCH IS A NEW CAM AND LIFTERS?YOU MAY BE MONEY AND TIME AHEAD to just replace with just new,just saying.
Re: Used Cam Break in?? [Re: dodge413] #1543081
12/07/13 08:07 AM
12/07/13 08:07 AM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
Unfortunately The Lifters Were Not Marked Which Lobe They Were from When They Were Removed. Supposedly The Cam Has Only A 1000 Miles On It And It Barely Has Any Evidence It Was Even Used.
IM sure someone has already told you to buy new lifters and break it in as if it was new. You wouldn't want to use the old lifters in your situation.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: Used Cam Break in?? [Re: BB65Barracuda] #1543082
12/07/13 10:53 PM
12/07/13 10:53 PM
mi
E
ERAT340 Offline
ERAT340  Offline
E
mi
Lemmee ask you this... if the previous owner wasnt happy with this cam, do you really think you will be?
