Page 2 of 3 1 2 3
Re: Aluminium fuel line pressure? [Re: Cab_Burge] #1542244
12/01/13 03:28 PM
12/01/13 03:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The Ethanol will eat non hard anadized aluminum just like Methanol does even our local E10% pump gas will OP, make sure and buy hard anadized coated, inside and outside aluminum line and fittings for your deal That or stainless steel lines Teflon lined hose will not be affected by either type of pure or mixed alcholol is what I have told by the airplane industry, Teflon is the answer for heat, pressure and corrosive liquids according to them
Even with hard anodized alum line it will crack the
hard coating when its bent with the bender... 2 things
that I know of arent effected by any fuel are Teflon
and Viton lined products... with Ethanol it carries
water and it corrodes the alum line when air contacts
it, but if it never sees air its not a problem..
but thats hard to do
Re: Aluminium fuel line pressure? [Re: Duner] #1542245
12/01/13 04:19 PM
12/01/13 04:19 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Mike I have aluminum on the 65.Its been on at least 8 years.Street driven.The rubber lined clamps work.I also use them on the brake lines.If I go to a pump etc in the rear Ill probally run the braid as its easier to do all the plumbing.Rocky
Chrysler Firepower
Re: Aluminium fuel line pressure? [Re: Duner] #1542246
12/01/13 04:29 PM
12/01/13 04:29 PM
Here
jcc Offline
jcc  Offline
Here
I think my choice will be stainless lines.
I agree, plus, any small fire and alum is gone and now a much worse fire, plus e85 options
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
Re: Aluminium fuel line pressure? [Re: jcc] #1542247
12/01/13 04:50 PM
12/01/13 04:50 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I just got a new roll of 5/8 Jegs brand aluminum fuel line and It specifically says max pressure 25# and also states that this product is not to be used on EFI systems,,in other words it's intended for plain old no frill's low pressure fuel line.
Re: Aluminium fuel line pressure? [Re: dartman366] #1542248
12/01/13 05:01 PM
12/01/13 05:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They must be running a thinner wall tubing now days
to say 25# max... they never use to say that... I
have a roll of 1/2" from Summit hanging on the wall
that I bought about a year ago and it didnt say that
Re: Aluminium fuel line pressure? [Re: MR_P_BODY] #1542249
12/01/13 05:27 PM
12/01/13 05:27 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
You can bet some lawyer was involved in that decision... either proactively before litigation or because of some.
Re: Aluminium fuel line pressure? [Re: Duner] #1542250
12/01/13 05:35 PM
12/01/13 05:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No doubt
Re: Aluminium fuel line pressure? [Re: Duner] #1542251
12/01/13 05:44 PM
12/01/13 05:44 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
that wouldn't be a suprise to me, according to the tag it also states that it is .035 wall seamless which I believe is industry standard, I am also thinking that maybe Jegs themselves are trying to make sure that the buyer is well aware of it's intended use, I also know that I have used a lot of Jeg's house brand Items and have yet to have a quality issue, as far as the OP, I am under the thinking he need's to definately step up to a much higher quality system than aluminum line, no matter who makes it.
Re: Aluminium fuel line pressure? [Re: dartman366] #1542252
12/01/13 08:28 PM
12/01/13 08:28 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I bought a 20 ft aluminum roll of 3/8 fuel line from Mancini in 2005. I run it from the stock tank to the front with just an electric pump by the tank. Its been on my 63 since 2006 as I ran it in the location the stock line ran. I have not had any issue's at all course I run about 6 psi. Ron
Re: Aluminium fuel line pressure? [Re: 383man] #1542253
12/02/13 12:56 AM
12/02/13 12:56 AM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Looked up the twist-tite hose Interesting how its not recommended for fuel line
Notes:
This hose is NHRA approved, however it is not recommended for fuel line use.
Our SummitŪ Twist-Tite hose was designed for reduced weight, increased flexibility, and, best of all, affordability. The hose features an elastomer inner tube bonded with a reinforced textile braid, and covered in high-temperature synthetic rubber. The hose is compatible with a wide variety of fluids and is good to 250 psi when used with our Twist-Tite fittings. The red and blue anodized fittings install without tools--they simply Twist-Tite.
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Aluminium fuel line pressure? [Re: CompWedgeEngines] #1542254
12/02/13 01:27 AM
12/02/13 01:27 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Inverteed flare steel line. The aluminum uses tube inserts or shoulders, but the biggest problem is it is very crack prone, and not what I would want on a 50PSI sytem.
I have run 1800 psi in 3/8" aluminum, but you need to make it right. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Aluminium fuel line pressure? [Re: astjp2] #1542255
12/02/13 02:07 AM
12/02/13 02:07 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
By right do you mean having the other end open? other wise I think your gage was off by about 1775 pounds
Re: Aluminium fuel line pressure? [Re: rowin4] #1542256
12/02/13 02:56 AM
12/02/13 02:56 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
25 psi limit is laughable.
Lets use 3003 alum which is sort of popular for fuel line IIRC. Tensile strength is in the 13K+ range if my data is correct.
Let figure out burst pressure!
P = (2t x S) / O
Where:
P is burst pressure in PSI
t is wall thickness, in inches .035
S is tensile strength of material in PSI 13,000
O is outside diameter, inches .375
P = (2*.035*13000)/.375
P = .070*13000/.375
P = 910/.375
P = 2426
That's just a bit more burst pressure than 25 psi...
Re: Aluminium fuel line pressure? [Re: RobX4406] #1542257
12/02/13 10:39 AM
12/02/13 10:39 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
P = (2t x S) / O
Where:
P = .070*13000/.375
P = 910/.375
P = 2426
When the aluminum line cracks with 50 psi pressure there's a really good chance of your car catching fire.
When it cracks under suction it will leak a lot less gas.
Aluminum will crack and leak eventually, just a matter of when.
Build a quality car and use steel, there's still only one right way to do it.
Re: Aluminium fuel line pressure? [Re: Challenger 1] #1542258
12/02/13 11:13 AM
12/02/13 11:13 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Exactly Gary. theres a big difference between running a hydraulic fluid line on a payloader, vs a fuel pressure line on a race car. I havent seen many fatalities in a payloader where a line cracked, and the operator got burned to death because he couldnt get his seatbelt off. I have seen people in trouble in race cars from broken fuel lines .
There is a point where simple common sense should take over, but many people will want to argue, because somewhere, there is engineering data to support their argument. ( I DO understand that). That being said, common sense should always prevail in a racing application. My
RIP Monte Smith
Re: Aluminium fuel line pressure? [Re: Duner] #1542259
12/02/13 11:24 AM
12/02/13 11:24 AM
Az
Crizila Offline
Crizila  Offline
Az
especially if he is streeting it at all. I did a set for my 300 a while back, using the stock routing. Not easy to work with though. Make the correct bend the first time when making up your lines, because rebending stainless is difficult.
Fastest 300
Re: Aluminium fuel line pressure? [Re: Crizila] #1542260
12/02/13 11:44 AM
12/02/13 11:44 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Absolutely. Street miles and the extended vibration and usage play havoc on things for sure...especially when you view it as "time" in use.
The decision for mine was only too easy since it's 98% street and only 2% race anyway. Besides - how much of a weight difference could there possibly be?
Re: Aluminium fuel line pressure? [Re: Duner] #1542261
12/02/13 12:03 PM
12/02/13 12:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Steel line for the same size is 2X the weight... I
dont mind making the line in steel but I wouldnt do
stainless.. that stuff is way to hard to work with..
and yes I've bent PLENTY of stainless lines while
I worked in the fuel lab.. and I have all the good
bending and flaring equipment... its just to hard to
correct if you mess up and too costly if you do mess
up... I never had any issues with the alum line on
my car and that was on there 10 years..... any leak
can cause a fire..... also if the alum line was so
bad the NHRA wouldnt allow it and they do... I would
bet 80% of the cars on this board and others run
the alum line
Re: Aluminium fuel line pressure? [Re: MR_P_BODY] #1542262
12/02/13 12:16 PM
12/02/13 12:16 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I don't doubt that aluminum might work fine for 90% of the cars out there. I just know my luck. I have to make stuff as bullet-proof as I can make it. I'm also not THAT worried about the added expense of something if I only have to do it once.
I ran an FMU setup on my ride for 7 years that would spike the fuel pressure beyond 150psi when in boost. In the mean time I did put another 50K miles on it in that configuration. That said - I've always worried about a fire for obvious reasons. I was doing it all wrong, but it DID manage to make 700hp thru a 1/4 fuel line. LOL
I'm working to pull it back from the brink of self-destruction with smarter choices.
Re: Aluminium fuel line pressure? [Re: SLOW67] #1542263
12/02/13 01:00 PM
12/02/13 01:00 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I just got earl pro form-o-flex and have had it on my car for 15 years now. Lots of pump gas race gas and even e85 for two years on the same lines. Buy quality from the start you get many years of service and ends up costing less in the long run. See no reason to use crack prone alum line on a race/street car. Will cost you much more if you have a fire.
Page 2 of 3 1 2 3
